vtec problems
Old Jan 19, 2005 | 07:44 PM
Doeboy's Avatar
Default vtec problems
well ok,
motor:92 d16z6
car: 92 cx
engine harness(motor harness): 92 d16z6
i am having trouble with my vtec engagment, all my wiring is hooked up and it is all correct. I have been told that all 92 civics were pre wired for vtec. so i have all that covered. Now i know that you cant really feel vtec engagment with a SOHC, but i do know you can hear it. My oil is full and the vtec solenoid is plugged in. I also have a V-AFC and it is getting a signal, saying the solenoid is turning on and off. I cant hear mine nor feel it. I am running extremely rich in higher RPM's. i have taken off the vtec solenoid and cleaned the screen, and i have gotten nothing. what else should i look for.
thanks in advance
drew
Old Jan 19, 2005 | 07:47 PM
hondaeg8's Avatar
Default Re: vtec problems (slowEh2)
are you throwing any codes?
when i drove my friends hatch with a jdm d15b vtec motor, i couldn't hear or feel vtec either, but it was working.
Old Jan 19, 2005 | 07:56 PM
HATCHingMN's Avatar
Did you swap the CX ecu for the P28 from an 92-95 EX or SI??
Old Jan 19, 2005 | 08:01 PM
street sleeper's Avatar
it may be working, on sohc motor you wont really hear vtec, or feel it , unless you have I/H/E, and even then you might not hear it.
Doeboy's Avatar
Default Re: vtec problems (street sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">are you throwing any codes?
when i drove my friends hatch with a jdm d15b vtec motor, i couldn't hear or feel vtec either, but it was working. </TD></TR></TABLE>
No, im not throwing any codes. and that is why im stumped
and yes i am running a p28 from the z6 its self
yes i have I/H/E sorry for no specification
Old Jan 19, 2005 | 08:03 PM
hondaeg8's Avatar
as stated above, are you using the right ecu?
if your not throwing any codes, then more than likely its working. your not going to hear or feel it like you would on a b series motor.....sorry.
Old Jan 19, 2005 | 08:04 PM
ieldib's Avatar
chances are it's working ... the single cam's just aren't very audible ....
JDM_Frijoles
Jun 16, 2006 05:18 PM
spoonInspired
Aug 20, 2005 03:36 AM
fasterthenmost
Sep 12, 2002 08:44 PM
bigblock-EG
Mar 26, 2002 08:36 AM
