whats the easiest way to fix a vacuum leak?
Old Jan 19, 2005 | 07:42 PM
DOHC_VTEC69's Avatar
Default whats the easiest way to fix a vacuum leak?
my car idles funny, it fluctuates between 1 and 4 grand and i was told it was a vacuum leak
Old Jan 19, 2005 | 07:46 PM
sohcvtec1995's Avatar
Default Re: whats the easiest way to fix a vacuum leak? (DOHC_VTEC69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC_VTEC69 &raquo;</TD></TR><TR><TD CLASS="quote">my car idles funny, it fluctuates between 1 and 4 grand and i was told it was a vacuum leak</TD></TR></TABLE>
where is the vacum leak? a bit more details would help
Old Jan 19, 2005 | 07:48 PM
SOHC4life 96's Avatar
Default Re: whats the easiest way to fix a vacuum leak? (sohcvtec1995)
Did you do anything recently to your car? Like pull something out or put something in? Please give us more information.
Old Jan 19, 2005 | 07:54 PM
TeamNextGenChris's Avatar
whats the easiest way to fix a vacuum leak?seal it!
if you have a vacuum leak between two mating parts,you need to remove the part,clean the mating surfaces,install a new gasket,then torque the fasteners to spec.
check your vacuum related hoses,make sure none have cracks in them,or none have fallen off their ports.
your problem also sounds like it could be a EACV/IACV problem-do a search for that,been covered 8.1 million times.
Chris
00gs-r
May 19, 2007 11:21 PM
EG9_808
Mar 2, 2007 11:23 AM
ic89
Oct 18, 2006 08:24 AM
abmerop18
Jul 16, 2006 07:10 AM
