rad fitment
Old Jan 19, 2005 | 07:36 PM
plastik462003's Avatar
Default rad fitment
will a rad from a gsr bolt up into a 91 si hatch? and will the fan from the si bolt up too?
i have a b16a engine in it.
another question is the hoses are alittle to big for the openings in the rad. will the hoses from the si fit on the engine or are they to small?
Old Jan 19, 2005 | 07:38 PM
eumoria's Avatar
Default Re: rad fitment (plastik462003)
i think it'll probably be too tall and you'd have to angle it. The hoses will connect in the same place, but the hood will not close with it standing on end.
I know the 90-92 teg rads fit, not 100% sure on the newer DC though, think it'd be too tall like the EG's. Someone else try this?
Old Jan 19, 2005 | 07:52 PM
Default Re: rad fitment (eumoria)
some more info please ordering it today thanks josh
Old Jan 20, 2005 | 06:05 AM
TTT
Old Jan 20, 2005 | 08:40 AM
NOBODY HAS ANY INFO ON THIS?????????????????
Old Jan 20, 2005 | 08:48 AM
Smokinsax's Avatar
The Boot
have you tried using the seach function...
it may be a little frustrating at first but stick to it and you may run across some info that you can use.
why do you want to use the dc rad in the first place? cause the one in the hatch is usless or you think the rad from the dc is an "upgrade"? Give us some more info here, there may be a better solution to your problem.
RA61825
Oct 31, 2008 03:59 PM
d15b2_ed6
Nov 22, 2006 07:09 PM
Hawkrider
Jan 8, 2002 05:51 PM
Blue-Civic-Hybrid
Jul 16, 2001 07:50 AM
