LS 98-99 - Suspension Difference?
Old Jan 19, 2005 | 05:34 PM
Deeg's Avatar
Default LS 98-99 - Suspension Difference?
Hey everybody. I've seen a couple differing opinions on this, so I just wanted to see if anyone knew for certain. Does the '99 GS have a different suspension (closer to the GS-R) than the LS, or are the differences strictly cosmetic? Thanks...
Old Jan 19, 2005 | 05:39 PM
TheGSRGuy's Avatar
Default Re: LS 98-99 - Suspension Difference? (Deeg)
RS, LS, GS, SE (AUTO TRANNY)
22mm front sway bar (94-99)
24mm front sway bar (00-01)
13mm rear sway bar
RS, LS, GS, SE (MANUAL TRANNY)
14mm rear sway bar
GS-R
24mm front sway bar
14mm rear sway bar
Front strut tower brace
Type R
24mm front sway bar
22mm rear sway bar
Rear trunk brace
Rear subframe brace
All springs/struts/LCAs are the same, excluding the Type R's.
So to answer your question, if it has a manual tranny, the rear sway bar will be 1mm thicker.....that's all.
Run Away
12
Aug 28, 2011 02:55 PM
dgdarien
Mar 21, 2005 11:09 PM
fluke83
Jul 8, 2004 10:05 PM
R91Si
Oct 12, 2002 08:36 AM
Gennady
Jan 11, 2002 05:30 PM
