automatic to 5 speed swap
questions on automatic to 5 speed swap
1. what parts do i need to swap (i have a full donor car)
2.are there any websites with this topic
3.how to remove the pedal assembly
any pics of this swap would be helpful also.....
you need a flywheel clutch 5 speed tranny shift linkage the ecu from the 5 speed a drill and a drill bit for a 12 mm bolt . when you take the center console apart you will see 2 nickel size circles drill them out. so you can bolt up the shiftlinkage up and there you go.
From: I told you to wait in the truck in Texas, United States
way to help there bro...
Try these :
http://hometown.aol.com/jrmupzaii/auto2man.html
http://www.trinituner.com/shop/manual.asp
Try these :
very time consuming, but you learn lots about your car, and will be a very fun car in the aftermath
don't forget however that some of the honda's (I know 5th gens for sure) you need to do something different for the ignition cylinder and key as it won't "know" if you are in park or not to be able to start it.
