help quick.
Old Jan 19, 2005 | 01:52 PM
HatchBox's Avatar
Skoobie no more...
Default help quick.
which is the 90 civic a-arm and which is the 90-93 integra a-arm?
Old Jan 19, 2005 | 02:09 PM
EL Vap133's Avatar
Default Re: help quick. (HatchBox)
Damn, too bad I'm at work right now. But on a wild guess, I would say the one on the left is the crx a-arm.
erebunicrx's Avatar
is the left one missing a piece? if not the right one is from a civic. i have the same one on my crx
Old Jan 19, 2005 | 02:12 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (erebunicrx)
hmmm 50 50....
the left one is missing the stock mounts it has a ingalls camber kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Damn, too bad I'm at work right now. But on a wild guess, I would say the one on the left is the crx a-arm. </TD></TR></TABLE>
(for later, just incase elvap is wrong)
Modified by HatchBox at 6:47 PM 1/19/2005
Old Jan 19, 2005 | 02:33 PM
SkRiBLaH's Avatar
Default Re: (HatchBox)
I remember my teg a arm had a thin piece like the one on the right. I'd say the right one is the integra one
Old Jan 19, 2005 | 02:34 PM
erebunicrx's Avatar
well if its missing that piece idk then. sorry about that
Old Jan 19, 2005 | 02:38 PM
XrcR6's Avatar
I'd vote that left = ED (missing bridge, probably since someone installed that camber kit) and right = DA (OEM).
From what I've read is that DA will fit since it has the same spacing between the anchor bolts. But you gain positive camber and less caster. The one on the right definitely seems to have a longer distance from the centerline of the anchor bolts to the upper ball joint. So that'd be the camber gain people speak of.
Old Jan 19, 2005 | 02:40 PM
BeaterKiller's Avatar
Are they both off the car? If not measure the other one and see. If they are both off the car, then you will have to do some searching.
Old Jan 19, 2005 | 02:48 PM
HatchBox's Avatar
Skoobie no more...
Default Re: help quick. (BeaterKiller)
well i got my swap, and got free knuckles, so while the timing belt was getting put on i had them zip on the teg ones...
So im thinking the skinny ones might be the civic.
Old Jan 19, 2005 | 02:50 PM
UNDER PRESSURE's Avatar
The right one is a teg arm.
Old May 10, 2005 | 04:58 PM
HatchBox's Avatar
Skoobie no more...
Default Re: help quick. (UNDER PRESSURE)
sorry to bring this back up, but im having difficulties, both hit the frame rail..
Old May 11, 2005 | 05:37 AM
HatchBox's Avatar
Skoobie no more...
confirm?
Old May 11, 2005 | 09:53 AM
user 98292739's Avatar
its not missing a piece when you put the camber kit on it doesnt come wiht that middle piece. the one on teh right is stock the one on the left has a camber kit hus missing that middle piece
Old May 11, 2005 | 10:08 AM
gnar kill's Avatar
pretty sure right one is teg...both come stock with that little peice and it doesn't matter which one you use.....I just did this swap in my rex with the entire teg setup......there are two little washer type things that should be on the end of your camber kit and if you don't use those it will hit the frame rail....I know because I tried to not use mine because it looks like they seat better without them....if you donm't have them just put about a 1/4 inch of washers on the both of those bolts and it should drop it enough that it will clear the frame rail.
Casey
Old May 11, 2005 | 10:15 AM
PaImportTuner's Avatar
ok just got a wiff of the thread and went outside to my 92 DA and it has the ones on the RIGHT and my EF CRX has the ones on the LEFT and same camber kit.
Old May 11, 2005 | 10:24 AM
HatchBox's Avatar
Skoobie no more...
Default Re: help quick. (PaImportTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner &raquo;</TD></TR><TR><TD CLASS="quote">ok just got a wiff of the thread and went outside to my 92 DA and it has the ones on the RIGHT and my EF CRX has the ones on the LEFT and same camber kit. </TD></TR></TABLE>
Thanks for looking!!
Hmm now i gotta figure out why its hitting the frame rail lip.
Think it would be ok to dremel it off?
Old May 11, 2005 | 10:28 AM
gnar kill's Avatar
don't dremel it!!!!!! just use washers read my post it is like 2 up
Old May 11, 2005 | 10:49 AM
HatchBox's Avatar
Skoobie no more...
Default Re: help quick. (gnar kill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">don't dremel it!!!!!! just use washers read my post it is like 2 up</TD></TR></TABLE>
dammit, well now i know what those were for... lol
importgod21682
12
Sep 28, 2006 11:07 AM
andrey320
Jun 7, 2006 02:12 PM
ozrednsx
Jun 1, 2006 07:12 AM
EF mark
46
May 30, 2006 01:29 PM
KillerTofu
Jul 11, 2004 10:06 AM
