camber kit
Old Jan 19, 2005 | 08:18 AM
Civic92Turbo's Avatar
Default camber kit
i did a search and i notice that may people like the skunk2 cambers over the omni....but if you hand the chance to pick one witch one?
Old Jan 19, 2005 | 08:21 AM
komat's Avatar
Default Re: camber kit (Civic92Turbo)
how much did you lower your car?
i did a 2.25inch drop my cx didnt need it
Old Jan 19, 2005 | 08:22 AM
hawaiianbro's Avatar
lol are you serious? if you did a search and found that most people like skunk2 over omni power i think you answered your question right there......but newayz the new skunk2 camber kits are a lot stronger than before. I have the new ones on now and they were perfectly..
Old Jan 19, 2005 | 08:51 AM
ocdcivic's Avatar
Default Re: camber kit (hawaiianbro)
Skunk 2
Old Jan 19, 2005 | 10:16 AM
yea i know its kind of funny...but i like both products and i dont really think it much of a deal...but i just want to see what others think....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawaiianbro &raquo;</TD></TR><TR><TD CLASS="quote">lol are you serious? if you did a search and found that most people like skunk2 over omni power i think you answered your question right there......but newayz the new skunk2 camber kits are a lot stronger than before. I have the new ones on now and they were perfectly..</TD></TR></TABLE>
Old Jan 19, 2005 | 10:42 AM
axhandler's Avatar
My understanding is that the two are functionally identical. The same guy that designed them for Skunk2 is the owner of Omni-Power. There was a thread discussing this topic a long time ago. I'll see if I can find it for you...
edit: Can't find the thread right now but here are some photos for comparison
SKUNK2
OMNI
Modified by axhandler at 2:53 PM 1/19/2005
Modified by axhandler at 2:59 PM 1/19/2005
Modified by axhandler at 3:00 PM 1/19/2005
Old Jan 19, 2005 | 11:43 AM
Swapped_EG's Avatar
skunk2
Old Jan 19, 2005 | 11:49 AM
K I O K E N's Avatar
Default Re: camber kit (Swapped_EG)
Skunk2 and Omni are identical. One has the Skunk2 logo and a 20% markup, the other doesn't.
Old Jan 19, 2005 | 11:53 AM
J.EM1's Avatar
Team Purple
Default Re: camber kit (ocdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ocdcivic &raquo;</TD></TR><TR><TD CLASS="quote">Skunk 2 </TD></TR></TABLE>
or Ingalls or SPC
Old Jan 19, 2005 | 12:35 PM
mycron's Avatar
Default Re: camber kit (SiDriven)
on the topic of ingalls, i just got a set for an awsome deal.
http://cgi.ebay.com/ebaymotors...=WDVW
comes with rubber bushings and ball joints. The guy has like 4 left and is a good ebayer (since some of you dislike ebay). Free S&H
Check it out if any of you need a set.
Old Jan 19, 2005 | 12:49 PM
AutoXer's Avatar
Default Re: camber kit (K I O K E N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K I O K E N &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 and Omni are identical. One has the Skunk2 logo and a 20% markup, the other doesn't.</TD></TR></TABLE>
I believe that the Skunk has been redesigned to be stronger and adjustable from the bottom of the arm now.
Old Jan 19, 2005 | 01:01 PM
damnecheck's Avatar
Default Re: camber kit (EX_AutoXer)
i have a friend that had troubles with omni... the bolts weren't strong enough and i have another friend with the new skunk 2's with no problem
Old Jan 19, 2005 | 01:02 PM
thelucysong's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swapped_EG &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 </TD></TR></TABLE>
Old Jan 20, 2005 | 11:50 AM
any one else?
Old Jan 20, 2005 | 11:54 AM
mooook's Avatar
Default Re: (Civic92Turbo)
are the Skunks adjustable?
i need to set my front camber straight... just curious if the Skunk setup will work?
Old Jan 20, 2005 | 12:00 PM
colinproctor's Avatar
Default Re: (mookvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mookvtec &raquo;</TD></TR><TR><TD CLASS="quote">are the Skunks adjustable?
i need to set my front camber straight... just curious if the Skunk setup will work?</TD></TR></TABLE>
they are camber correction upper control arms, of course they are adjustable.
Old Jan 20, 2005 | 12:10 PM
POE's Avatar
POE
my ingalls were 80 shipped, and they do the job
Old Jan 20, 2005 | 02:28 PM
stock99's Avatar
ingalls
Old Jan 20, 2005 | 03:13 PM
CrxEDguY's Avatar
Default Re: camber kit (stock99)
after a little while the boot with all the grease in it cracked on my skunk 2 camber kit but it still did the job. i still have them and currently not using them.
Old Jan 20, 2005 | 03:25 PM
ocdcivic's Avatar
Default Re: camber kit (CrxEDguY)
how long did you have your skun 2's on before they started to go?
Old Jan 21, 2005 | 09:48 AM
AutoXer's Avatar
I'm assuming you have bad tire wear. If so, did you get an alingment and set the toe to 0? If not, that's why your tires are wearing. Toe kills tires, not camber.
Old Jan 21, 2005 | 09:53 AM
Kyles ej1's Avatar
Default Re: camber kit (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">
i did a 2.25inch drop my cx didnt need it </TD></TR></TABLE>
i dont know exactly how much i lowerd my car (its 1 finger gap) anyone knoe how much that is for a stock ej1 i know its more than 2" but anyways i didnt need one either.
Old Jan 21, 2005 | 10:43 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: camber kit (93blkej1)
Have you guys seen the new SKUNK2 camber kit? It has a top hat/support on the screws on top of the ball joint. The old ones are identical but theres a new skunk2 and its better than before
see the difference?
Old Jan 27, 2005 | 09:36 AM
CrxEDguY's Avatar
Default Re: camber kit (BrokeAssPinoy)
it started to go roughly about 7-8 months
BoOsTiN Dc2
Suspension & Brakes
Sep 8, 2005 04:49 AM
ToiletFetusSushi
Apr 13, 2004 11:56 PM
Nocturnal
13
Jan 25, 2004 04:18 PM
JDM CTR EK
Aug 22, 2003 03:15 PM
dLo GSR-stolen-now-WRX
Jul 13, 2002 01:06 AM
