camber kit
camber kit
i did a search and i notice that may people like the skunk2 cambers over the omni....but if you hand the chance to pick one witch one?
Re: camber kit (Civic92Turbo)
lol are you serious? if you did a search and found that most people like skunk2 over omni power i think you answered your question right there......but newayz the new skunk2 camber kits are a lot stronger than before. I have the new ones on now and they were perfectly..
Re: camber kit (hawaiianbro)
yea i know its kind of funny...but i like both products and i dont really think it much of a deal...but i just want to see what others think....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawaiianbro »</TD></TR><TR><TD CLASS="quote">lol are you serious? if you did a search and found that most people like skunk2 over omni power i think you answered your question right there......but newayz the new skunk2 camber kits are a lot stronger than before. I have the new ones on now and they were perfectly..</TD></TR></TABLE>
My understanding is that the two are functionally identical. The same guy that designed them for Skunk2 is the owner of Omni-Power. There was a thread discussing this topic a long time ago. I'll see if I can find it for you...
edit: Can't find the thread right now but here are some photos for comparison
SKUNK2
OMNI
Modified by axhandler at 2:53 PM 1/19/2005
Modified by axhandler at 2:59 PM 1/19/2005
Modified by axhandler at 3:00 PM 1/19/2005
SKUNK2
OMNI
Team Purple
Re: camber kit (ocdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ocdcivic »</TD></TR><TR><TD CLASS="quote">Skunk 2 </TD></TR></TABLE>
or Ingalls or SPC
or Ingalls or SPC
Re: camber kit (SiDriven)
on the topic of ingalls, i just got a set for an awsome deal.
http://cgi.ebay.com/ebaymotors...=WDVW
comes with rubber bushings and ball joints. The guy has like 4 left and is a good ebayer (since some of you dislike ebay). Free S&H
Check it out if any of you need a set.
Re: camber kit (K I O K E N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K I O K E N »</TD></TR><TR><TD CLASS="quote">Skunk2 and Omni are identical. One has the Skunk2 logo and a 20% markup, the other doesn't.</TD></TR></TABLE>
I believe that the Skunk has been redesigned to be stronger and adjustable from the bottom of the arm now.
Re: camber kit (EX_AutoXer)
i have a friend that had troubles with omni... the bolts weren't strong enough and i have another friend with the new skunk 2's with no problem
Re: camber kit (Swapped_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swapped_EG »</TD></TR><TR><TD CLASS="quote">skunk2 </TD></TR></TABLE>
Re: (mookvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mookvtec »</TD></TR><TR><TD CLASS="quote">are the Skunks adjustable?
i need to set my front camber straight... just curious if the Skunk setup will work?</TD></TR></TABLE>
they are camber correction upper control arms, of course they are adjustable.
Re: camber kit (stock99)
after a little while the boot with all the grease in it cracked on my skunk 2 camber kit but it still did the job. i still have them and currently not using them.
Re: (mookvtec)
I'm assuming you have bad tire wear. If so, did you get an alingment and set the toe to 0? If not, that's why your tires are wearing. Toe kills tires, not camber.
Re: camber kit (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">
i did a 2.25inch drop my cx didnt need it </TD></TR></TABLE>
i dont know exactly how much i lowerd my car (its 1 finger gap) anyone knoe how much that is for a stock ej1 i know its more than 2" but anyways i didnt need one either.
Honda-Tech Platinum Member
Re: camber kit (93blkej1)
Have you guys seen the new SKUNK2 camber kit? It has a top hat/support on the screws on top of the ball joint. The old ones are identical but theres a new skunk2 and its better than before
see the difference?
see the difference?
JDM CTR EK
08-22-2003 03:15 PM
