2005 Suzuki Z250 ATV
Formerly Mike@TSR
Re: 2005 Suzuki Z250 ATV (Z)
here are pics i could find of it. with the autoclutch and shaft drive its pretty much a beginners atv and good for a smaller kid or a girl,
here are the specs also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Specs
Engine: 246cc, 4-stroke, single-cylinder, air-cooled, SOHC, 2-valve, TDCC
Bore Stroke: 66.0 x 72mm
Compression Ratio: 9.2:1
Fuel System: MikuniBSR29
Lubrication: Wet Sump
Ignition: Electronic iginition (CDI)
Transmission: 5-speed with reverse, automatic clutch
Final Drive: Shaft
Overall Length: 1720mm (67.7 in.)
Overall Width: 1070mm (42.1 in.)
Overall Height: 1090mm (42.9 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: 230mm (9.1 in.)
Wheelbase: 1135mm (44.7 in.)
Dry Weight: 166kg (366 lbs.)
Suspension Front: Independent, double A-arm, oil damped, adjustable preload, 6.1 inches of travel
Suspension Rear: Swingarm-type, oil damped, adjustable preload 6.1 inches of travel
Brakes Front: Dual hydraulic disc
Brakes Rear: Mechanical Drum
Tires Front: AT 22 x 7-10
Tires Rear: AT 20 x 10-9
Fuel Tank Capacity: 10.6 liter (2.80 gal.)
Color: Yellow, White
Final Drive: Shaft
Formerly Mike@TSR
Re: 2005 Suzuki Z250 ATV (stockcrix1616)
exact pic, but ours is white.
Selling it just because we dont need it. We had a 94 banshee that had a broken clutch basket and just traded it for that.
Fl_civic_rider
21
05-26-2004 06:50 AM
