Suspension & Brakes Theory, alignment, spring rates....
How do I fix my offset ?
Old Jan 19, 2005 | 04:37 AM
Daniel san's Avatar
Default How do I fix my offset ?
my car came with 205/55/15 rims
and I since then added Koni yellows and Eibach springs.
My car is NOT slammed, but when I have extra weight, like a passenger. the tires keep on rubbing.
so my rim offset is obviously wrong
how can I fix this without getting new rims ?
Old Jan 19, 2005 | 06:46 AM
Mike_C's Avatar
options: roll your fenders, ensure there aren't any wheel spacers being use. i'm rubbing on the outside is what concerns you?
that is a very large tire, you may just be out of luck.
Daemione's Avatar
Default Re: How do I fix my offset ? (Daniel san)
First figure out where it's rubbing - outside of the tire, or the inside. If the outside is rubbing, your offset is too low. If the inside is rubbing, it's too high.
You can find spacers to lower the offset, or you can take the wheels to a machine shop to remove material from the hubs to raise the offset. If you remove material, make sure there's enough on the hub to retain the strength necessary. And I wouldn't take off more than 5mm that way.
Stiffer springs could help too - you've got pro-kits, I assume? Even a marginal increase in spring rate to H&R or Neuspeed sports might make the difference you need.
edit: oh yeah - rolling the fenders is a good idea to try first.
Old Jan 19, 2005 | 11:10 AM
RineRacing's Avatar
If rolling the fenders isn't enough you could switch to a 205/50/15 or even a 195 tire.
Using a Kumho 712 tire as an example:
195/50/15 = 22.7" overall diameter
205/50/15 = 23.1"
205/55/15 = 23.9"
Old Jan 19, 2005 | 11:29 AM
Mordeki's Avatar
Abusing my rights one day at a time.
Default Re: How do I fix my offset ? (RineRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RineRacing &raquo;</TD></TR><TR><TD CLASS="quote">If rolling the fenders isn't enough you could switch to a 205/50/15 or even a 195 tire.
205/50/15 = 23.1"
205/55/15 = 23.9"</TD></TR></TABLE>
, rolling the fenders should be fine though...
Old Jan 19, 2005 | 02:06 PM
Moogen Powah's Avatar
Default Re: How do I fix my offset ? (Mordeki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">First figure out where it's rubbing - outside of the tire, or the inside.</TD></TR></TABLE>
If it rubs on the outside, either roll the fenders, and/or get 195s. Or if it rubs on the inside, spacers would seem like the way to go. BTW, I'm lowered on H&R Sports w/ a +31 offset on 195s w/o rubbing.
Old Jan 19, 2005 | 02:33 PM
PrettyLude's Avatar
You have the option of rolling your fenders or you can increase negative camber in the rear. I believe it's ok as long as it's no more than -1.5 degrees.
Old Jan 19, 2005 | 05:52 PM
slammed_93_hatch's Avatar
holly HUGE tires, get ride of those damn things
Old Jan 19, 2005 | 10:52 PM
Tad's Avatar
Tad
Default Re: How do I fix my offset ? (slammed_93_hatch)
those tires are indeed too tall
205-50-15 is taller than the oem tiresize,
so 205-55-15's is even worse..
Old Jan 20, 2005 | 07:08 AM
motion's Avatar
Default Re: How do I fix my offset ? (Tad)
Tires are indeed the culprit. Either run 205/50, which will allow a shorter sidewall and wider tire or 195/55 (stock tire size for a 99-00 Si), which is a taller sidewall and thinner tire. Do you know what your offset is at right now?
Old Jan 20, 2005 | 08:29 AM
BolivianDc2's Avatar
Default Re: How do I fix my offset ? (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote"> or you can take the wheels to a machine shop to remove material from the hubs to raise the offset. If you remove material, make sure there's enough on the hub to retain the strength necessary. And I wouldn't take off more than 5mm that way.
have you ever done this personally? I have asked a couple people about this before and they said it was not worth the risk of damaging the strength of the rim
Old Jan 23, 2005 | 09:15 AM
Daniel san's Avatar
Default Re: How do I fix my offset ? (BolivianDc2)
I just double checked my tires, and they are 205/50/15
Old Jan 23, 2005 | 12:17 PM
your tire could be rubbing on the plastic fender lining
Old Jan 24, 2005 | 07:33 AM
motion's Avatar
What rims are you running?
RHD_EK9
Oct 9, 2010 08:45 PM
3rdgen3
Suspension & Brakes
Mar 16, 2009 03:18 PM
timbs7
Mar 17, 2007 02:39 PM
dkrangers
Jul 24, 2004 11:31 AM
Chiller
Jun 30, 2003 02:32 PM
