grinding noise when turning:(
Hi
Noticed today when going up a carpark that when I turn hard lock to the left there is a grinding/tapping noise from the front of the car. I thought it might be a ball joint or wheel bearing? any other ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">most likely to be your cv boot</TD></TR></TABLE>
you dont get your oil changed at any cheap shop do you??
cuz theyre fukin scandalous they'll rip your cv boot and then tell you your cv boot is rippd and hope that u get them to fix it lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Special-Ed »</TD></TR><TR><TD CLASS="quote">
cuz theyre fukin scandalous they'll rip your cv boot and then tell you your cv boot is rippd and hope that u get them to fix it lol</TD></TR></TABLE>
man if i find a dealer that does that i would sue there *** and make there buniess a pooper
Modified by komat at 8:58 AM 1/19/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennisp »</TD></TR><TR><TD CLASS="quote">Hi
Noticed today when going up a carpark that when I turn hard lock to the left there is a grinding/tapping noise from the front of the car. I thought it might be a ball joint or wheel bearing? any other ideas?</TD></TR></TABLE>
If your car is lowered or if you have plus-sized rims and tires you're probably rubbing at full lock. If not, it's either a CV joint (axle...it's easier to replace and just as expensive) or a thrashed wheel bearing.
thx for the responses.
Ill get the guys to check the whole lot out.
Btw, its running on 16's, 45 profile, and dropped 35mm on ITR shocks.
Thanks for the help
Thanks for the help
D for D series
Jan 29, 2005 09:08 PM
