Swap Info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackassasin95 »</TD></TR><TR><TD CLASS="quote">Could someone give me a list or tell me where I could find a list of everything I need to swap K20a2 into my 95 civic coupe?</TD></TR></TABLE>
Search is your friend.
You need
Mounts
Header
Axles
Harness
Fuel rail
Fuel Lines
Fuel Regulator
Shifter Box
intake
Shifter cables
Throttle cable
Shifter linkage Clips
EP3 belt
EP3 Bracket w/pulley
Thermo unit
Throttle cable
Switch Coolant
Clutch Line
for more info you can search, look at my website etc..
You need
Mounts
Header
Axles
Harness
Fuel rail
Fuel Lines
Fuel Regulator
Shifter Box
intake
Shifter cables
Throttle cable
EP3 belt
Thermo unit
Throttle cable
Switch Coolant
Clutch Line
Alberto
Feb 16, 2005 09:48 AM
