ZC or D16 into '91 Civic Si
Old Jan 18, 2005 | 08:42 PM
2K4K20's Avatar
Default ZC or D16 into '91 Civic Si
Hey, I was wondering if anybody could point me in the direction of some good sites that provide information for swapping either a ZC motor or D16Z6 into my '91 Civic Si. Also, I believe a ZC swap is easier, but any feedback would be great. Thanks in advance.
Old Jan 18, 2005 | 09:02 PM
mrspeaker's Avatar
Default Re: ZC or D16 into '91 Civic Si (Gen4Civic)
ZC swap info
D16z6 swap info
Check out this thread
https://honda-tech.com/zerothread?id=637661
Old Jan 19, 2005 | 05:27 AM
2K4K20's Avatar
Default Re: ZC or D16 into '91 Civic Si (Mrspeaker)
Hey, thanks for the direction. Does anyone know whether or not the Si ECU will accept the wiring for the Cam angle sensor. It is on (I think) all DOHC engines, on the second cam, usually the exhaust side. If that is the only wire I will have to add, I'm going for the ZC with turbo. Any suggestions?
Old Jan 19, 2005 | 03:51 PM
mar778c's Avatar
Community Builder
Community Influencer
Yes, the SI ECU will work on a DOHC ZC.
That swap can be pretty quick but make sure you get a good set of mounts or you will be in wheel hop hell.
Old Jan 19, 2005 | 03:54 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: ZC or D16 into '91 Civic Si (mar778c)
chalk up another for ZC
Old Jan 20, 2005 | 05:47 AM
RACINTWEEK's Avatar
Default Re: ZC or D16 into '91 Civic Si (Ace$nyper)
ZC all the way
the ZC cam sensor is on the end if the exhaust cam where as the Si one is in the dizzy
you need to cut the blue/green and blue/yellow wires from the Si dizzy and solder them to the cam sensor on the ZC
Old Jan 20, 2005 | 06:07 AM
2K4K20's Avatar
Default Re: ZC or D16 into '91 Civic Si (RACINTWEEK)
Thanks. Am I also to understand that that is the only extra wiring I will have to play with? Does everything else hook right up? I have a problem believing it to be that easy. It would be great if it is.
Old Jan 20, 2005 | 06:14 AM
EP3_05's Avatar
That is all the wiring you need to do. Since you have an si it is pretty much a plug and play swap.
Old Jan 20, 2005 | 06:57 AM
RACINTWEEK's Avatar
even if you have never done anything mechanical in your life it shouldnt take more than 3 or 4 hours to swap
Old Jan 20, 2005 | 07:02 AM
2K4K20's Avatar
Well, I swapped a ZC into a '93 Civic DX, and it was a nightmare. It uses the same mounts, among other things, but the wiring was terrible. So, all I have to do is splice the two wires that went into the old Distributor, and wire them to the Cam Angle Sensor, right? Evrything else plugs right in?
Old Jan 20, 2005 | 07:09 AM
RACINTWEEK's Avatar
thats all the wiring changes
you **might** have to just extend some wires if they dont reach
Old Jan 20, 2005 | 07:14 AM
2K4K20's Avatar
Thanks for the advice. I might be doing the swap this weekend. I'll post some pics if anyone is interested.
patrickstar
22
Mar 2, 2009 04:40 PM
ninjapanda
Nov 30, 2005 03:16 PM
whitehf
Aug 23, 2005 07:31 PM
Horse_Balls
Jun 18, 2004 01:31 PM
91civicguy
Apr 17, 2001 06:23 AM
