shuddering/popping when braking...
Old Jan 18, 2005 | 08:16 PM
jadugartir's Avatar
Default shuddering/popping when braking...
For awhile now my car has made a shuddering shaking movement you can feel in the car and in the pedals when stopping... I only have 3 lugs on one wheel but its on tight, i was wondering if that may be the problem since its on the passenger side. Any ideas?
Old Jan 18, 2005 | 08:17 PM
ls_vtec_crx's Avatar
it could be that or your brake rotors are warped.....
Old Jan 18, 2005 | 08:19 PM
jadugartir's Avatar
Default Re: (ls_vtec_crx)
yeah im reading up on a full integra disc brake swap, i got store credit at the junkyard
Old Jan 18, 2005 | 09:26 PM
B16 ED9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_vtec_crx &raquo;</TD></TR><TR><TD CLASS="quote">it could be that or your brake rotors are warped.....</TD></TR></TABLE>
Old Jan 18, 2005 | 09:59 PM
travis's Avatar
Default Re: (B16 ED9)
Before you go buying a whole set of brakes, consider turning your current rotors and buying a lug nut.
Old Jan 18, 2005 | 11:40 PM
XrcR6's Avatar
Default Re: (travis)
^ Make note of the "and" Travis used. Because whether you turn the existing rotor, buy a new one or swap to the Integra stuff; if you keep using 3 lugnuts you will keep warping the rotor and this will keep happening.
globy123
16
Aug 21, 2007 05:23 PM
eg4life1202
Oct 29, 2006 10:09 AM
WalkerGSR1
Suspension & Brakes
Aug 13, 2006 02:36 PM
Vic_GSU
16
Jul 11, 2004 04:10 PM
turbod96ex
Sep 25, 2003 03:28 PM
