nitrous set up info
Old Jan 18, 2005 | 07:27 PM
DelSolDon's Avatar
Default nitrous set up info
considering a nitrous setup on my sol. i got a jdm obd1 b16a w/stock internals, looking at about a 75 shot or so. this is not my daily driver, but still want it to be reliable. i am pretty knowledgable about honda's and such, and know basics about "the bottle", but please enlighten me. any opinions/ facts about wet or dry, which brand setup is better, timing and fuel adjustments, etc. would be appreciated. thanks in advance.
Old Jan 19, 2005 | 03:27 PM
DelSolDon's Avatar
Default Re: nitrous set up info (DelSolDon)
bump
Old Jan 19, 2005 | 03:42 PM
darkd1gt's Avatar
most ppl will say go with wet... but i kind of like the dry system the computer makes all the adjustments and there is way less to go wrong ie solenoid hangin up but 75 would be max on dry shot. I would say get colder plugs and retard the timing a few degrees though on either system. personally im gettin a bag system to go on my lude 50 shot it plugs into the cig outlet for power has a button and u just run one line really simple
Old Jan 20, 2005 | 12:23 PM
DelSolDon's Avatar
Default Re: nitrous set up info (mattspivey)
even retard the timing if the computer is doing the "adjusting"? if so, would i be able to get away with just moving the dizzy or do i have to get adj. cam gears? i've heard retard 1.5 to 2 degrees for every 50 hp, correct if wrong.
Old Jan 20, 2005 | 05:11 PM
darkd1gt's Avatar
if u have an odb1 motor the dizzy adjust would be ok, i have no idea about the odb2 i guess cam gears is how they do them just dont spray over a 50 on dry.
Old Jan 24, 2005 | 06:43 PM
DelSolDon's Avatar
bump for a n2o noob tryin to get the low down.
XzIpK
May 13, 2007 07:16 PM
vmsturbo
Aug 21, 2004 06:29 PM
8891hatchs
Jun 14, 2004 07:27 PM
DissidentCivic
Jan 18, 2004 09:51 AM
twizt2
Dec 19, 2001 12:03 PM
