tach install problem
I just installed a tach and the thing won't read my rpm's. This is how I hooked it up:
Red: to cigarette lighter
Black: grnd on cigarette lighter
White: to dimmer switch
green: blue wire on dizzy
The tach lights up and it gets power to the connectors but it won't read rpm's.
What could it be?
What could it be?
I am assuming this is an autometer tach (if so) it needs to be calibrated. There are two wires on the back I think one is blue and the other is brown. You need to clip one to calibrate it. I belive it is the blue one.
Must be different for other models. I have a autometer c2 and there was a brown and blue wire. Any way it tells you in the instructions which ones to clip.
what there saying is, you your self need to pick between 4-6-8 cylinders.by cliping the wires on say a autometer,you are then selceting how many cylinders for it to read.there may also be a hidden switch.
Civicse
77
Dec 15, 2004 05:13 PM
