How Do I Remove These Bushings? (pics)
Old Jan 18, 2005 | 03:43 PM
litterbox's Avatar
I am a (Trial User) Army
Default How Do I Remove These Bushings? (pics)
Hey,
I recently purchased an Energy Suspension Hyperflex bushing kit. I've pushed in the front and rear lca bushings but I need to push these bushings out.
http://www.we-todd-did-racing....D.jpg
How can I do it without ruining the bracket or bushing? Or will I have to ruin the bushing to get it out.
Thanks.
Modified by litterbox at 11:31 PM 1/18/2005
Old Jan 18, 2005 | 04:04 PM
Archidictus's Avatar
Unceasing Measure
Default Re: How Do I Remove These Bushings? (litterbox)
Can't you remove the nut and slide the washer and bushing assemblies off?
Old Jan 18, 2005 | 04:19 PM
litterbox's Avatar
Default Re: How Do I Remove These Bushings? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Can't you remove the nut and slide the washer and bushing assemblies off?</TD></TR></TABLE>
Yes, that's how you get it off the arm. But then I need to get the bushing out of the bracket. That's what I'm asking about.
Old Jan 18, 2005 | 04:31 PM
SyDuck's Avatar
im pretty sure you have to press them out
Old Jan 18, 2005 | 04:35 PM
pgpunkguy's Avatar
Default Re: How Do I Remove These Bushings? (SyDuck)
yup, need a press to take them out and to put the new ones in...
Old Jan 18, 2005 | 04:38 PM
Lord Helmet's Avatar
yeah you need to press them out
Old Jan 18, 2005 | 04:39 PM
litterbox's Avatar
Default Re: How Do I Remove These Bushings? (pgpunkguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy &raquo;</TD></TR><TR><TD CLASS="quote">yup, need a press to take them out and to put the new ones in...</TD></TR></TABLE>
That's not entirely true. For my lca's I pressed new ones back in with a big *** vice from home-depot. I did need a press to get them out though.
I think I'll be able to press these ones back in with a vice but I was just wondering if any of you had a good tip or trick to get them out.
Old Jan 18, 2005 | 04:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">
I think I'll be able to press these ones back in with a vice but I was just wondering if any of you had a good tip or trick to get them out.</TD></TR></TABLE>
I normally grease up my bushings before I press them out. makes it alot easier.
Old Jan 18, 2005 | 07:15 PM
pgpunkguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">That's not entirely true. For my lca's I pressed new ones back in with a big *** vice from home-depot. I did need a press to get them out though.
a vice is essentially a type of press, mechanically speaking...
Old Jan 18, 2005 | 07:36 PM
DelSolDon's Avatar
i did my rear LCA bushings the redneck ohio way. i used a hacksaw to cut through the bushing from the inside out on one side and then used a punch and a BFH (big f*cking hammer) to pound it out. take the hack saw blade loose, then stick it through the hole in the bushing and re-attach it to the hack saw and cut away. i also lightly sanded the area where the new bushing slides into to ease installation. yeehaw!
Old Jan 18, 2005 | 10:35 PM
FRANK_WHITE's Avatar
i can already hear the squeeking jk bring em to a local auto repair shop or machine shop have them press em in its cheap and save yourself a lot of agony lol
Old Jan 19, 2005 | 01:18 PM
litterbox's Avatar
Default Re: (FRANK_WHITE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRANK_WHITE &raquo;</TD></TR><TR><TD CLASS="quote">i can already hear the squeeking jk bring em to a local auto repair shop or machine shop have them press em in its cheap and save yourself a lot of agony lol</TD></TR></TABLE>
It's not cheap. Every shop I went to wanted $100 to do the lca bushings. I was told it was cheap on HT before I went to check out actual pricing. Most people on here will tell you it's cheap, I guess it's because they haven't actually done it.
Old Jan 19, 2005 | 03:30 PM
DelSolDon's Avatar
Default Re: (litterbox)
^^or they're just indepently wealthy. try my way if you want, just don't forget your pabst blue ribbon and your BFH.
Old Jan 19, 2005 | 03:47 PM
hayabusa160's Avatar
Default Re: (DelSolDon)
take the bolt off. and they will come right out i did mines those were the easiest out of all of them.
if not use a utility knife cut a few chunks off the edges and slide them out. a press is not required you can push them out with your hand.
just use a knife or a hack saw cut the edges of the rubber off and they will pretty much push right out. thats how i did mines.
to put the new ones in put them in a vice and tighten and it will press right in. use some wd40 if you want to ease it in.
Old Jan 19, 2005 | 03:58 PM
DelSolDon's Avatar
Default Re: (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">use some wd40 if you want to ease it in.</TD></TR></TABLE>
i prefer KY warming liquid
Old Jan 19, 2005 | 04:01 PM
litterbox's Avatar
Well I was going to try and preserve these bushings but it looks like that won't happen so I'll cut them and press them out.
Old Jan 19, 2005 | 04:14 PM
bah why save them lol
Old Jan 19, 2005 | 04:21 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">bah why save them lol</TD></TR></TABLE>
Well because I'm not sure if the new ES ones will fit properly, I had to return a kit because they were too loose. Then they replaced it with the same kit for the same car, and they now fit.
Old Jan 19, 2005 | 04:22 PM
litterbox's Avatar
One more thing, do these bushings run the risk of squeaking like the lca ones? I'll grease the hell out of them, one way or the other, but I'd like to know.
Old Jan 19, 2005 | 04:25 PM
i never had any sqeaking problem had them sence aug.
just lub them up good
i had the black ones tho
Old Jan 19, 2005 | 04:26 PM
litterbox's Avatar
Default Re: How Do I Remove These Bushings? (hayabusa160)
Mine are black too.
jonnydbagz
Jun 15, 2007 03:42 PM
OMG WTF
Suspension & Brakes
Jul 20, 2006 07:49 PM
KRiS1
Jul 25, 2003 12:11 PM
Urban Business
Apr 21, 2003 07:19 PM
Jaminak
23
Jun 6, 2002 12:57 PM
