abs light on after shock install
Old Jan 18, 2005 | 11:41 AM
alfee's Avatar
Default abs light on after shock install
alright, i just put on some new shocks yesterday, didn't drive it till this morning and i noticed the ABS light is now on. what's the cause of this? should i take the negative wire off the battery and plug it back on to reset or what?
Old Jan 18, 2005 | 01:24 PM
JimBlake's Avatar
Default Re: abs light on after shock install (alfee)
Read the error codes for your ABS. Check out the sticky post (top of Integra forum) about "ECU & ABS codes". Maybe you pulled the wire apart for a wheel sensor?
Old Jan 18, 2005 | 01:48 PM
mmuller's Avatar
Mad Scientist
Default Re: abs light on after shock install (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote"> Maybe you pulled the wire apart for a wheel sensor?</TD></TR></TABLE>
thats what im thinking
Old Jan 28, 2005 | 10:22 AM
alfee's Avatar
Default Re: abs light on after shock install (mmuller)
ok i did the abs light flash test yesterday and got a 4-4 flash meaning its the wheel sensor on the Right Rear. so i took my rim off and checked all the lines, nothings wrong??? what could the be? everything's bolted correctly.. hrmmm... any suggestions?
Old Jan 28, 2005 | 10:28 AM
JimBlake's Avatar
Is it a 3rd-gen Integra like your picture?
I thought you gotta take off the brake rotor before you can even see the sensor. Then follow the wire. You said 'lines' so were you only looking at the hydraulic hose? The sensor is magnetic, so you can check if it's got a pile of metal shavings stuck to it??
Follow the wire to where it goes thru a hole into the body. Then root around under the carpeting in the trunk where it comes thru. Somewhere there's an orange plug. Loose? Broken? Keep following the wire to the ABS controller, it's nearby...
Old Jan 28, 2005 | 10:32 AM
alfee's Avatar
k thanks, will do that then.
Old Jan 28, 2005 | 10:35 AM
mmuller's Avatar
Mad Scientist
listen to jim, he's the funk masta flex
Old Jan 28, 2005 | 11:12 AM
Mikey's Avatar
You will get code 4-4 if you have a bad wheel speed sensor. This can be caused from an internal failure in the w.s.s. itself, and/or it may be that there is gunk in the toothed ring. I'd check and clean the toothed ring as well as check all connections of the w.s.s. If everything checks out, replace the w.s.s.
Old Jan 28, 2005 | 12:47 PM
Chiovnidca's Avatar
Default Re: abs light on after shock install (Mikey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey &raquo;</TD></TR><TR><TD CLASS="quote">You will get code 4-4 if you have a bad wheel speed sensor. </TD></TR></TABLE>
Usually if the wheel speed sensor is bad it will show up with a resistance check.
chazt
Honda CR-V & Element
Apr 16, 2013 01:04 PM
Whatislove
Honda Civic (2001 - 2005)
16
Jun 14, 2009 01:53 PM
dblas
Acura TL, RL & ZDX
Feb 23, 2007 02:40 PM
Rob!
Jan 12, 2005 05:53 PM
Nighthawk GS-R
Aug 5, 2001 11:04 PM
