EG oxygen Manual Wiring
Old Jan 18, 2005 | 11:34 AM
Equilibrium's Avatar
* B A N N E D *
Default EG oxygen Manual Wiring
My situation: I had my EG stolen a few months ago, and am still working out the bugs in the motor that these thieves have caused. My motor (JDM SOHC ZC) is running very strong, I can easily keep up with my friends LS (JDM B18B) w/ Type R Trans (LSD). I noticed however that my Vtec isn't engaging; I've assumed this is because my O2 sensor wiring has been cut and it is not throwing a code, disabling Vtec!? I've read the wiring diagram, and this is what I can tell the pinout will be; can you concur?
Black O2 - Yellow/black (Injectors) (A13 and B1)
Black O2 - Orange/Black (A16)
Green O2 - Green/White (D22)
White O2 - Orange/Blue (D18)
Also, while viewing the pinout, I noticed the yellow/black wire goes through all the injectors, Evap Purge Solenoid, and the A13/B1 pins; should I just splice into once of the Yellow/Black wires, or directly connect it to A13 and B1?
Finally, how do I know which Black is which???
Any help and wiring techniques/theory, would be appreciated. Please note, I only have worked on wiring which requires "Current (12v and grounds)" not really signals (ECU/ECM's).
Old Jan 18, 2005 | 04:12 PM
* B A N N E D *
Default Re: EG oxygen Manual Wiring (Equilibrium)
Bump
Old Jan 18, 2005 | 04:57 PM
poison's Avatar
All of the Yel/Blk's go to the same place, which is sourced from A25 -- which is the sensor positive pinout.
They all run to a Yel/Blk junction harness on the driver side passenger harness with a circuit plug plugged into it.
As for the blacks, it doesn't matter. It's the voltage sources, needed with a ground & sensor power. That's about it.
good luck.
Old Jan 19, 2005 | 11:25 PM
* B A N N E D *
Default Re: EG oxygen Manual Wiring (poison)
Bump
Any more thoughts before I do this???
Old Jan 21, 2005 | 01:19 AM
* B A N N E D *
Not a one???
OoAoO
Jun 27, 2011 10:09 PM
full Circling
Engine Management and Tuning
May 11, 2010 07:15 PM
crxblues
Mar 30, 2009 06:06 AM
patastinky
Jul 19, 2005 01:24 PM
done
Jun 20, 2004 02:36 PM
