1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!!
Old Jan 18, 2005 | 10:43 AM
W O T's Avatar
Default 1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!!
I want to install me eg 1/2 rad before the install in 2 months. I was looking at some EG 1/2 rads from streetimports, dual core, aluminum.
But thats all it comes with, the rad.
Like can I just relocate my 88Crx overflow tank to make it work with the EG one?
FAN: Can I make the stock Crx fan fit onto the 1/2 rad or should I be switching to something else
Im going to have a ramhorn style mani, external gate, 3" downpipe passenger side so will OEM fan fit?
Wiring:If I use the stock fan then yeah wiring is the same but if I have to buy another slim one or one for an EG will it just plug in?
Does anyone have any guides or pics of there eg 1/2 rads installed?
I dont see why it wont be easy if I just make a bracket and bang it around for mounting but does any cutting have to be done?
Thanks guys
Old Jan 18, 2005 | 10:48 AM
EP3_05's Avatar
Default Re: 1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!! (W O T)
Just another thing to think about. They do make half size radiators for the crx now too. I believe PWR, C&R, Fluidyne, make half size radiators for the crx now.
Old Jan 18, 2005 | 11:35 AM
APEX CRX's Avatar
I used an EG Fluidyne radiator for my CRX. I got it before anything else was available. I used a Fal slim fan for an EG and cut off my old fan plug and soldered it to the FAL. Haven't had a problem yet.
For the coolant overflow bottle, I just bought some new hose in bulk and ran it across under the radiator support to the stock overflow.
Old Jan 18, 2005 | 01:08 PM
slowpokesi's Avatar
you will need a slim fan, i think the stock shroud sticks out like 2 inches,
in fact i had to get a pusher fan, i was limited on room, get a slim fan, and you can cut the plug off your oem fan and use it to wire up your aftermarket fan.
as far as the radiator goes, if you are going to buy a new radiator, get the c&r shorty for the crx its the only radiator as of yet that fits in the crx without some retarded *** mounting, fullrace is also developing a crx radiator, pm them to find out when it will be available.
for the overflow tank just get a long hose and run it over to the tank so it will mount in the original location, however, if your intercooler piping is going to be in that area you will have to find a diffrent way to do it, what are you doing about the battery?
i will post a picture of my setup tommorow for you,
Old Jan 18, 2005 | 09:59 PM
W O T's Avatar
Default Re: 1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!! (slowpokesi)
battery will be going in the trunk
Old Jan 19, 2005 | 01:27 AM
W O T's Avatar
CRX specific radiators are looking to be expensive as hell
I can get a EG 1/2 rad aluminum for less than half the price
Dont mind a little ghetto bracket moutings lol, dont see why not
Old Jan 19, 2005 | 10:06 AM
W O T's Avatar
Old Jan 19, 2005 | 10:32 AM
APEX CRX's Avatar
Here's a pic of my setup. I still need to make a top mount.
[IMG][/IMG]
Old Jan 19, 2005 | 01:34 PM
GSRCRXsi's Avatar
Default Re: 1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!! (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">Here's a pic of my setup. I still need to make a top mount.
why bother if you are still N/A? IMO you only need a half sized radiator if you are turboed. cause if you have the room, a full sized will always cool better then half sized.
Old Jan 19, 2005 | 10:15 PM
W O T's Avatar
Default Re: 1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!! (GSRCRXsi)
Can you post some overhead shots of that? so I an check the clearances and such
cmon slowpoke, I wanna see yours to
Old Jan 21, 2005 | 11:50 AM
W O T's Avatar
Old Jan 21, 2005 | 11:57 AM
Chronicsinners's Avatar
is that still using the stock crossmember??
Old Jan 21, 2005 | 12:02 PM
Smokinsax's Avatar
The Boot
APEX CRX: what kind of modification(s) did you have to make to get that rad to fit? Cut the "webbing" out of the hood or did you fab up some lower brackets to make it sit right?
Old Jan 21, 2005 | 01:13 PM
TEAM HATCH-N-IT 90's Avatar
Default Re: (Smokinsax)
NICE!!!!!!!!!!!!! i like your crx with the b18c1 SWEET choice how hard was that to put in? i have a 90 hatch dx and i was thinking of b18 swap or a b16a
Old Jan 21, 2005 | 02:05 PM
90civichbsi's Avatar
Default Re: (CIVICking90)
here is mine, using a place racing crossmember and then i just cut a hole in the hood webbing and installed the grommet for the top mount in the webbing.
Old Jan 21, 2005 | 02:25 PM
APEX CRX's Avatar
Default Re: 1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!! (Chronicsinners)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronicsinners &raquo;</TD></TR><TR><TD CLASS="quote">is that still using the stock crossmember??</TD></TR></TABLE>
If this question was for me??? then yes. I still have my stock x-member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">APEX CRX: what kind of modification(s) did you have to make to get that rad to fit? Cut the "webbing" out of the hood or did you fab up some lower brackets to make it sit right?</TD></TR></TABLE>
I drilled out the stock lower radiator mounts and re-welded then in the lowest position possible on the lower support. I did have to cut some of the webbing on my CF hood so the radiator cap wouldn't rub. I heard some people have angled the radiator back to solve the top rubbing problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVICking90 &raquo;</TD></TR><TR><TD CLASS="quote">NICE!!!!!!!!!!!!! i like your crx with the b18c1 SWEET choice how hard was that to put in? i have a 90 hatch dx and i was thinking of b18 swap or a b16a </TD></TR></TABLE>
not that hard. did all the RESEARCH first, then bought the parts and did the swap myself.
Modified by APEX CRX at 1:54 PM 1/23/2005
Old Jan 21, 2005 | 05:53 PM
88 rex's Avatar
https://honda-tech.com/zerothread?id=1111393
Here's what you're looking for........
Seems like a no brainer to me.......good luck!
Old Jan 21, 2005 | 07:23 PM
W O T's Avatar
Default Re: 1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!! (88 rex)
just bought a bitchin slim fan
trying to get streetimports to accept money orders so I can grab a alum rad
and thanks for that link
Old Jan 21, 2005 | 08:30 PM
coot_er's Avatar
im thinking about doing the neon radiator
http://www.geocities.com/neonradiator/neon.html
post pics and comments if you have done this please
Old Jan 21, 2005 | 08:35 PM
honda06si's Avatar
Default Re: (90civichbsi)
[QUOTE=90civichbsi]QUOTE]
whoa that valve cover is killa...howd u do that?
Old Jan 21, 2005 | 08:38 PM
W O T's Avatar
Default Re: (honda90si)
i think they call it paint....
I dunno though, paint is a very unheard of substance
Old Jan 21, 2005 | 08:51 PM
honda06si's Avatar
Default Re: (W O T)
i hate smartasses.....i wasnt talkn to u......did you tape up the letters and just spray it wit some high temp? howd u get that fade look?
Old Jan 21, 2005 | 09:13 PM
W O T's Avatar
I hate dumb ***** who jack threads with ricer comments. If you want to flash out your valve cover, pm the man
Old Jan 21, 2005 | 09:22 PM
ICeDoUt's Avatar
Default Re: (W O T)
damn no need to be hostile...
But anyways back to the topic. When i installed the 1/2 rad on my rex using the stock x-member i didn't ghetto fab up any mounts, i just jammed it in there. And zip tied it so it wouldn't move, And still had to cut out some of the hood underskeleton, and it still hit a lil. also just got the overflow tank floating around in the engine bay
Old Jan 21, 2005 | 09:59 PM
HondaKPX's Avatar
Default Re: (ICeDoUt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">damn no need to be hostile...
But anyways back to the topic. When i installed the 1/2 rad on my rex using the stock x-member i didn't ghetto fab up any mounts, i just jammed it in there. And zip tied it so it wouldn't move, And still had to cut out some of the hood underskeleton, and it still hit a lil. also just got the overflow tank floating around in the engine bay</TD></TR></TABLE> I would make some mounts i dont like things "floating around" and ziptied
