kinda OT: how do I put my turbo kit on and run NO boost?
It's itr related.....
I can't get in to any hondata dealers locally (they're all ***** or booked up for the most part). I need to have my base map rescaled + burned to a chip, and the boost option on my hondata turned on, so in the meantime I'm up **** creek.
I need to send my hytech header off to it's new owner and I can't have any downtime due to work.
So..... can't I just install the turbo without running any boost? It's internally gated, but can't I just do something to hold the wastegate open?
-tia!
-tia!
What turbo and can you take a pic of the housing where the wastegate attaches? It could be as simple as detaching the wastegate from the wastegate flapper. It'll always stay open and prevent any boost being built.... or should ;p
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">It could be as simple as detaching the wastegate from the wastegate flapper.</TD></TR></TABLE>
The wastegate diaphragm and housing will basically melt/break down if you leave it open all the time, it will never have a chance to cool. Just be patient and don't install it until you have the tuning to back it up. buy a cheap **** header to get you through...
Or just leave it, install your boost gauge and drive like a granny. I found it wasn't really that hard to stay out of boost during normal driving conditions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFedDetroit »</TD></TR><TR><TD CLASS="quote">The wastegate diaphragm and housing will basically melt/break down if you leave it open all the time, it will never have a chance to cool..</TD></TR></TABLE>wtf?
r0cker said = "It's internally gated"
My internal wastegate has no issue with heat if it is open or closed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">why would jOO not want any bOOst???
did you read the post??????
</TD></TR></TABLE>did you read the post??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard »</TD></TR><TR><TD CLASS="quote">wtf?
My internal wastegate has no issue with heat if it is open or closed.</TD></TR></TABLE>
yup, my bad, didn't see him mention that it was internal...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cletus »</TD></TR><TR><TD CLASS="quote">did you read the post??????</TD></TR></TABLE>
I WAS JOKING
I WAS JOKING
Just dont use alot of load (light on the gas pedal) and you will stay out of boost. It is not hard to stay out of boost.
easy .. just keep your foot off the floor.
another words, use self controll and keep heR in "vacume"
From: First in Flight, Type Rs of East Coast, NC, FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR »</TD></TR><TR><TD CLASS="quote">easy .. just keep your foot off the floor.
another words, use self controll and keep heR in "vacume"</TD></TR></TABLE>
Dont use v-attack ?
Dont use v-attack ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">People still use FMUs..... ewww...
:shakes head:</TD></TR></TABLE>
yup and you can still make 400whp on em what is your point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 »</TD></TR><TR><TD CLASS="quote">yup and you can still make 400whp on em what is your point</TD></TR></TABLE>
It can be cheaper to chip the ecu and have Real fuel management..... Thats my point.
not for OBD2 but either way it works and works well<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">
It can be cheaper to chip the ecu and have Real fuel management..... Thats my point.</TD></TR></TABLE>
sigh whatever. you run your fmu... i'll chip my ecu. I like standalone quality engine management that is actually management... not just ... boost? dump fuel....
please call the guys at inline pro and tell them their 10 second street cars have been a flook for the last 6 years.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 »</TD></TR><TR><TD CLASS="quote">Just dont use alot of load (light on the gas pedal) and you will stay out of boost. It is not hard to stay out of boost.</TD></TR></TABLE>
maybe with YOUR turbo
I was thinking the same thing. Nate with my turbo it is pretty hard to stay out of boost really. anything more than 25% throttle it would roll into boost at as low at 2000rpms
</TD></TR></TABLE>I was thinking the same thing. Nate with my turbo it is pretty hard to stay out of boost really. anything more than 25% throttle it would roll into boost at as low at 2000rpms
