Security light is on, ECU Swap
Old Jan 18, 2005 | 08:03 AM
agrabau's Avatar
Default Security light is on, ECU Swap
Is there anything short of a reflash that will help us get this car started after an Auto-to-manual swap?
Thanks in advance.
Alex
"» No Results Found
Your search for ECU swap security returned no results.
Please try different search criteria or a different data set."
Old Jan 18, 2005 | 08:29 AM
6SPD_EK's Avatar
Default Re: Security light is on, ECU Swap (agrabau)
do you have paper work (documentation) for your new ECU? if so bring it to an acura/honda dealer (with new ECU & your key for the car) & the should be able to reprogram it - to match your key
If they say the cannot, INSIST (ask manager to call acura/honda) they double check - because it can DEFINITELY be done
don't forget to bring your spare key too ^
or send the ECU to hondata dealer (see http://www.hondata.com) & have them remove the immobilizer function (you will not have this form of security)
Old Jan 18, 2005 | 09:50 AM
agrabau's Avatar
Default Re: Security light is on, ECU Swap (adirondackR)
For the record/archives it looks like Honda needs the diagnostic port to change the key settings so the car has to be present. Is this true? Proof of otherwise?
A
Old Jan 18, 2005 | 12:37 PM
krystar's Avatar
yes your car has to be present because they need to power up the ECU, connect it to the immobilizer ring, and have your key inserted in the immobilizer ring.
Old Jan 19, 2005 | 04:28 AM
agrabau's Avatar
Default Re: (krystar)
My GF has an immobilizer ring. I should ask her.
hard_boiled_EG
Oct 15, 2009 05:16 PM
JDM.Sleeper
Jun 9, 2005 08:05 AM
Big Si Guy
Dec 30, 2003 03:55 PM
Big Si Guy
Dec 30, 2003 07:18 AM
HotWheelz
Dec 23, 2003 10:14 PM
