JDM D15B cam in D16z6
Old Jan 18, 2005 | 07:36 AM
EFz6er's Avatar
Default JDM D15B cam in D16z6
What kind of gains would this yield...I found a D15B head for cheap and wondering if its worth getting and swapping cams.
I have ebay intake and custom cat-back for mods.
Thanks in advance
Old Jan 18, 2005 | 07:40 AM
eumoria's Avatar
Default Re: JDM D15B cam in D16z6 (EFz6er)
the D15B cam is much more aggressive than the Z6 cam. Some people even equate it to the Zex 55410. I guess depending on the price it's worth it.
By Ebay Intake, do you mean just a CAI, or some no-name intake mani?
Old Jan 18, 2005 | 08:08 AM
EFz6er's Avatar
Default Re: JDM D15B cam in D16z6 (eumoria)
by ebay intake I mean CAI......could I keep everything stock and just throw in the D15B cam?
Old Jan 18, 2005 | 03:53 PM
eumoria's Avatar
yea you could, you may want to play with the timing... if you could get some Dyno time that would be your best bet to figure out where best to place it. Def a good upgrade.
Old Jan 18, 2005 | 04:00 PM
untitled's Avatar
yes me and toyosupr(neukin) were talking abou this yesterday. He bought a OBX stg1 cam for his z6 before he swapped the d15b in and found out that the stock d15b cams vtec specs were the same lift as most stg1's... Def a good upgrade.
It will make more power than a stock d15b and will pull good up top. I recommend a ls/b16 throttle body with this too. Better for matching it in upper RPMS where that cam will make power... possibly get it bored by maxbore.com to 62mm for $100 and then port match you IM to the TB,
^see how u can get carried away!
Old Nov 15, 2008 | 03:36 PM
lek9l's Avatar
Default Re: JDM D15B cam in D16z6 (untitled)
Better cam, and advanced timing. That is the only difference.
Old Jun 29, 2014 | 01:04 PM
rainmanef's Avatar
sorry to revive this thread. anyone know if stock timing marks can be used on this swap?
Old Dec 31, 2014 | 07:55 AM
rainmanef's Avatar
Bump
Old Jan 2, 2015 | 07:34 AM
4drEF's Avatar
Keyboard Humorist
^ if you are actually doing this swap, then you have both cams and can put the cam gear on both cams making reference to the cylinder 1 lobe to see if timing is the same, RIGHT?
Old Jan 3, 2015 | 03:56 AM
DCRB's Avatar
Hey I have a d15b vtec cam in my a6/z6 frankenstien, I had to use a y8 cam gear to get the timing to line up correctly
Old Jan 3, 2015 | 11:41 AM
steazyb's Avatar
Interesting I'd like to see a write up on this
Old Mar 29, 2015 | 04:30 PM
rainmanef's Avatar
bump
rainmanef's Avatar
any help. I've searched all over and nothing. Or at least nothing clear.
blackeg
Nov 15, 2008 03:44 PM
b.serious
Nov 15, 2008 03:34 PM
b.serious
15
Nov 15, 2008 03:32 PM
Bulli Kid
Feb 5, 2007 08:01 PM
