Need help with LS build up!!!!!!!!
Old Jan 18, 2005 | 07:29 AM
sedansleeper's Avatar
Default Need help with LS build up!!!!!!!!
I have a 97 lx 4 door honda civic. Like most people I want to keep it a sleeper, I have a LS engine and I was wondering if I could install GSR camshafts or even to a greater point can I install ITR camshafts. I would normally go with after market camshafts, but the problem is I am running on a low budget build up and I have a the opportunity to get ITr or GSR camshafts for cheap.
Old Jan 18, 2005 | 07:34 AM
JoeD427's Avatar
Default Re: Need help with LS build up!!!!!!!! (sedansleeper)
those cams will not work because they are vtec cams, you need aftermarket ls(non-vtec) cams.
Old Jan 18, 2005 | 10:25 AM
I have also thought about getting a v-tec head on the block. Would I then be able to do such conversion of camshafts, or will it still be a problem.....
Old Jan 18, 2005 | 10:36 AM
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sedansleeper &raquo;</TD></TR><TR><TD CLASS="quote">I have also thought about getting a v-tec head on the block. Would I then be able to do such conversion of camshafts...</TD></TR></TABLE>
Yes.
Old Jan 18, 2005 | 10:56 AM
e g - s i x's Avatar
you might wanna build up the block when you put the head on, so it'll be more reliable..remember ls blocks aren't made to rev to 8k
Old Jan 18, 2005 | 10:57 AM
ExospeedAMcrx's Avatar
We have performance camshafts for the LS head if you decide to stick with that. There are many cams available for the VTEC head if you decide to go that route.
But you cant interchange the cams from those heads. they are totally different design.
Old Jan 18, 2005 | 10:58 AM
NathanMorris's Avatar
Default Re: (aznxlunatik)
Check out my signature for LS non-VTEC build up people @ nonvtec.com. Also, you may look at LS/VTEC though reliability is "questionable" (it just depends on who/how it's built).
- Nathan
Old Jan 18, 2005 | 11:27 AM
Del Sizzle's Avatar
Default Re: (92Lx)
True, I had a LS/Vtec in my eg hatch for awhile, and it worked fine with no problems. I would only build the bottom if you're planning to go turbo.
Old Jan 18, 2005 | 04:26 PM
I mean I really dont plan to go turbo, I just want people to think I am slow, and out run them when they least expected.....
96 LS Turbo
Nov 15, 2013 01:29 PM
domestic abuser
Jun 7, 2006 04:50 PM
Civic44
Jun 1, 2004 08:35 PM
ggangtong81
Sep 26, 2003 06:19 AM
wm5holla
Apr 21, 2003 02:57 PM
