Primary and Secondary 02 sensor question
Old Jan 18, 2005 | 07:00 AM
shadykit's Avatar
Default Primary and Secondary 02 sensor question
Can I use a secondary o2 sensor as a primary? is it the same sensor?
Old Jan 18, 2005 | 07:11 AM
Deemeetree's Avatar
Electrician
Both have different part numbers. So, they might not work. I'm guessing 1 monitors oxygen before the cat then 1 monitors after the cat. So, the readouts might be different. Or, I might just be blabbing out of my ***.
Someone on here who has used both can chime in...
Old Jan 18, 2005 | 07:14 AM
georgj's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Both have different part numbers. So, they might not work. I'm guessing 1 monitors oxygen before the cat then 1 monitors after the cat. So, the readouts might be different. Or, I might just be blabbing out of my ***.
Someone on here who has used both can chime in...</TD></TR></TABLE>
I thought the only difference was the length of the wires for different positions. I may be way off here also, but that was my thoughts.
Brad
Old Jan 18, 2005 | 07:16 AM
Deemeetree's Avatar
Electrician
That could also be it. I wouldn't think they would be different. An O2 sensor, should be an O2 sensor, whether it be before or after the cat.
Old Jan 30, 2005 | 01:08 PM
Trailz-EX's Avatar
Default Re: (Dimi)
wow.. can any one confirm this... cuz there is a big difference in the price of sensors before and after the cat.. if they are the same just longer wires or different connectors or something then it would be cool to buy the cheaper on and just cut up the wiring a bit
Old Jan 30, 2005 | 01:12 PM
dantastic's Avatar
Default Re: (georgj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgj &raquo;</TD></TR><TR><TD CLASS="quote">I thought the only difference was the length of the wires for different positions. I may be way off here also, but that was my thoughts.
Brad</TD></TR></TABLE>
you're thinking right. the universal part # for the 2 sensors is the same. the only difference is the length of the wires.
i'm using a secondary sensor off a 99 ex as the primary (only) 02 sensor on my b18b
Old Jan 30, 2005 | 01:15 PM
pdiggitydogg's Avatar
theyre the same functionally
Old Jan 30, 2005 | 01:18 PM
dantastic's Avatar
Default Re: (Trailz-EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trailz-EX &raquo;</TD></TR><TR><TD CLASS="quote">wow.. can any one confirm this... cuz there is a big difference in the price of sensors before and after the cat.. if they are the same just longer wires or different connectors or something then it would be cool to buy the cheaper on and just cut up the wiring a bit</TD></TR></TABLE>
if you're going to cut up wires, you might as well buy the denso universal replacement. its the same as the oem direct fit one, minus the oem style plug
Old Jan 30, 2005 | 01:20 PM
Trailz-EX's Avatar
Default Re: (pdiggitydogg)
i dont know the exact honda price difference but i know the bosch difference is like thirty dollars and they dont even have the connectors on them.. you have to wire them your self.... would any four wire sensor work? just find a really cheap one and wire it up..
Old Jan 30, 2005 | 01:54 PM
Trailz-EX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
if you're going to cut up wires, you might as well buy the denso universal replacement. its the same as the oem direct fit one, minus the oem style plug</TD></TR></TABLE>
this is how the bosch sensor comes.. about how much for the denso sensor? is one better than the other? (i have a big problem with o2 sensors lasting more than a month for some reason, very excited about find a cheap way to fix them)
obd2 sucks by the way
Old Jan 30, 2005 | 02:20 PM
tuphatt's Avatar
Default Re: Primary and Secondary 02 sensor question (kitchale)
I got denso o2 sensor off of ebay by the seller name of "sparkplugssource"
It was about $45 for the universal and $50 for the direct plug on the first sensor. The second one you have to use the universal unless you want to spend about $75 for a direct plug.
I bought the direct plug on the first and universal on the second. Becareful wiring the second one. I think the wiring is different. They come with decent instructions.
Good luck!
shawn_crx
May 20, 2009 09:29 PM
sohc vtec rex
Mar 18, 2008 01:16 PM
baiwldrnner
Honda Civic (2001 - 2005)
13
Jul 15, 2007 10:04 AM
AllSpedup04
Oct 10, 2005 01:52 PM
BLUE EH3
14
Jun 19, 2005 10:16 PM
