Suspension & Brakes Theory, alignment, spring rates....
omni heigh adj. problems
Old Jan 18, 2005 | 06:26 AM
civic702's Avatar
Default omni heigh adj. problems
i followed the instructions with the preloading part by doing the 19mm nut being flushed. when i tightened the spring perch and spring lock everything is fine until i start to turn the shock body in order to adjust the ride height. as i'm turning it clock wise (lowering the height) the 19mm nut moves from being flush to not flush from the piston threading. am i preloading it wrong???
Old Jan 18, 2005 | 10:44 AM
civic702's Avatar
Default Re: omni heigh adj. problems (civic702)
anybody???
Old Jan 18, 2005 | 04:07 PM
lsvtec101's Avatar
the 19mm nut is moving itself down the thread i dont get what your saying?
loosen the 19mm nut till its flush with the top, tighten the spring perch and lock until the washer hits the 19mm nut. then install coilovers, then adjust.
DC4GB
Suspension & Brakes
Jul 23, 2006 05:56 PM
OutlawCL
Suspension & Brakes
Mar 6, 2006 09:51 PM
fsck3r
14
Mar 25, 2005 04:40 PM
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
F.U.D.
Suspension & Brakes
10
Jan 13, 2005 01:16 PM
