rear disk brake convertion question
i was wondering if the rear disc brakes off a 90-93 integra will fit on my crx an how much modifaction is needed if any?
thanks in advance
J.D.
thanks in advance
J.D.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbeastcrx »</TD></TR><TR><TD CLASS="quote">i searched and it only came up with results for the si</TD></TR></TABLE>
your rear brakes will be the same in design as the 89 Si's, the sizes might be slightly different but you still follow the directions all the same.
https://honda-tech.com/zerothread?id=590973
I searched and found this, it should show you every part you need. the swap is pretty straight forward. just pull parts off fand put new ones on. then be sure to get it aligned
I searched and found this: https://honda-tech.com/zerothread?id=930462
2K4K20
Jan 20, 2005 09:14 PM
JapJunkie
Jul 22, 2004 11:15 AM
hulkhb
Jun 14, 2003 01:23 PM
