A darton Built block, it a good idea? look at link? anyone hear any good or bad!?
hi im lookign to purchase this block and hte JG head they sel for another $900, and they assembled it, anyone ever used this block or anyting? i knwo darton is good but im just looking for others that might have used it check it out and let me know
http://cgi.ebay.com/ebaymotors...33615
i have just asking if anybody used it at all or know anyone, noway i can search that, thanks for the help though
only thing i would look into is the high compression numbers, 11:1 for turbo is higher than most. It can work amazing with the right set-up, but that set-up probably won't exceed 22psi with that kind of compression. You'd be in for alot more engine management **** with that high of compression, you could be a little more laxed with a 9:1 set-up. 11:1 is freaking high for boost.
