tighten/loosen balljoints?
Old Jan 17, 2005 | 08:43 PM
mymeatb18
Default tighten/loosen balljoints?
what is a good way to tighten balljoint nuts wwhen i go to put **** together. specifically my front spindles.
you cant say air tools thats cheating.
Old Jan 17, 2005 | 08:50 PM
Jonathan_ED3's Avatar
.....how about a regular wrench/ratchet?
I've never had a problem doing it that way.
Old Jan 17, 2005 | 08:54 PM
eda6's Avatar
Default Re: tighten/loosen balljoints? (mymeatb18")
Use a torque wrench.
lower ball joint=40 ft.lbs
upper ball joint/tie rods=32 ft.lbs
Old Jan 17, 2005 | 08:56 PM
travis's Avatar
Default Re: tighten/loosen balljoints? (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">Use a torque wrench.
Air tools to tighten is generally a bad idea unless the torque spec exceeds the torque of your impact wrench.
b20vtech
Apr 1, 2008 03:07 PM
93CamaroLT1
May 31, 2006 06:57 PM
komat
16
Jun 2, 2005 08:14 PM
vidanator
May 20, 2005 04:46 PM
david90
Aug 6, 2003 03:42 AM
