Suspension & Brakes Theory, alignment, spring rates....
Rear right noise on the car, I am lost. Please enlighten me.
Old Jan 17, 2005 | 06:32 PM
Nova_Dust's Avatar
Default Rear right noise on the car, I am lost. Please enlighten me.
Sorry, not sure if this is the right forum, if not, please delete or relocate, thanks.
It started off as rear disc brake swap. My car, 2000 DX hatchback, donor car, 2000 SiR. Everything was swapped over, the compensator arm, trailing arm (with ES trailing arm bushing replaced), brake line and whanot. Except the rear upper control arm, since my looks to be in better condition.
So the swap was done and after 2 weeks, rear clicking sound kicked in. Then I looked on H-T for possible causes of problem and did some exercise of pulling the wheel, and it turned out the bearing was bad. My rear wheel could be pulled outwards if I pulled hard enough. About 1/4" of play. So tonight, the bearing was replaced (btw, for 99-00 Si/SiR, rear hub/bearing assy. w/o ABS uses 42200-ST7-C51. I hope I got the part number correct).
After the installation, on my way home, I heard the same annoying sound. It is a sound of some metal pounding against another metal part, like a big "CLUNK" sound. I will try to describ it the best I could.
I was making a right turn into a gas station. So the car entred the gas station ramp from the street. This turning position caused the car to shift its body to the rear left, since the car was making a up-ramp right turn. So that made the rear right wheel to sort of "drop" because the car was tilting left. That's when the noise was made.
I think the trailing arm should be straight because alignment was done after 4 wheel disc brake swap. Bushing was new. The bearing went and that is new now. I checked rear sway bar and tighted everything so no loose nuts down there.
Could it be suspension?
Thanks
mikekc99
Sep 25, 2008 09:33 AM
mikekc99
Sep 17, 2008 07:07 AM
purple98ek
Apr 15, 2007 12:25 PM
chadmasterc
Suspension & Brakes
Jan 18, 2007 07:03 PM
Nova_Dust
Jan 18, 2005 06:56 PM
