D15b2 Rebuild........
Does anyone here kno a place I can get full engine rebuild kit. i.e (rod and crank berrings, piston rings, and gaskets??) I need to get a kit because im completely rebuilding my motor so I have zero miles on it..Its a d15b2 with a mini me swap on it.. Let me kno the details..
And if anyone is intrested ill keep pics of the process. But forgot to take the before I stripped the block...
http://www.hi-performance.com/...inder
might be cheaper just to find a used short-block....
I was going to do the same with my d15b2, but the machine shop qouted me "approx" 1500$ after I brought everything to them in pieces, all they had to do was replace the bearings, gaskets, rings, and re-assemble....
needless to say, I went and purchased a Z6 and converted to obd1 for half of that.
dude thats crazy...the machine shop by my house is really cheep..the rings,bearings and the rod beraring will cost me approx, $110.00 so id go and buy you **** from autozone and do it your self..but get it honed at the machine shop tho....
if you can take it a part you can put it back together. Get a book for all of you torque specs and sequences. Got to Autozone and get all your of your prices, then go to O'Rilley's and order all your parts with their price match. I say this because Autozone with have prices but won't be able to get some of the product. It took me about 2 hours to rebuild mine, but I had to file the rings myself. You can use some Lucas oil stabilizer to lube all of your bearings and for lubing the cylinder walls. It doesn't take much either. Here are some prices, hope this helps.
Rod Bearings List 30.49 Price 17.99 Part No. FED 4-1520CP
Main Bearings List 55.92 Price 32.99 Part No. FED 6699MA
Oil seal Front List 18.63 Price 10.99 Part No. NAT 710332
Premium Ring (Chrome) Set List 103.37 Price 50.99 Part No. SPO E515KC
These are O'Reilly Auto Parts List Prices and Part No. The Prices are Autozone.
They may not be the same for you, I'm in Batesville, Arkansas, and some things are a lot cheaper over here, like houses. lol I had prices on the head gasket and the rear main seal too, but I can't find my invoice on those. I think it was some where around 170.00 for all of that stuff combined. Not bad for a rebuild. Good Luck
Oh yea, the complete rebuild kit is some where around 300.00
b16bri
Oct 11, 2010 05:39 PM
