Check Engine light on
Old Jan 17, 2005 | 05:29 PM
mseawell's Avatar
Default Check Engine light on
I have a '97 2.2 Accord. The code reader provided the following code: PO141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2). Any suggestion as to how to fix this? Where is this sensor located?
Thanks,
Mark
Old Jan 17, 2005 | 09:14 PM
jeffreytard's Avatar
Default Re: Check Engine light on (mseawell)
It is the second O2 sensor, in the converter. Heater failure codes are pretty clear cut. Check voltage between the two black wires, there w3on,t be any. If you are under 150,000 miles you will still be under Hondas emission extension warranty and it will be free.
jayrod7
Jan 21, 2010 01:45 PM
mtime
Dec 17, 2009 09:17 PM
greyejcoupe
Oct 3, 2009 10:48 AM
mattkins91
Mar 1, 2009 02:07 PM
civicsaremean
Jul 15, 2007 07:59 PM
