need helpw ith swap
Old Jan 17, 2005 | 04:39 PM
civicdust's Avatar
Default need helpw ith swap
Okay, im almost done swapping the d15b into my 94 ex coupe, but i am having trouble putting back some hoses.
1. There is a black cylinder shaped object on the fire wall that has two "pipes" sticking out of it. On the top, there is a small round shaped object and it says PCV. Where do those go?
2. On the intake manifold, near the throttle body, there is also a "pipe" where does that go?
3. on the manifold there also a pipe, near the head on the passenger side, where does that go to?
Thanks
Jose!
Old Jan 17, 2005 | 04:58 PM
civicdust's Avatar
Default Re: need helpw ith swap (Jose!)
I also found one om top of the throttle body
Old Jan 17, 2005 | 07:00 PM
civicdust's Avatar
Old Jan 17, 2005 | 10:28 PM
civicdust's Avatar
help?
Old Jan 17, 2005 | 10:32 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jose! &raquo;</TD></TR><TR><TD CLASS="quote">Okay, im almost done swapping the d15b into my 94 ex coupe, but i am having trouble putting back some hoses.
Do you mean your Charcoal Canaster? Thats for smog, the PCV line hooks up to your manifold somewhere (cant remember off the top of my head)
Where on the throttle bottle? You either need a pic or a better discription, like were it goes, could be for cooling or for FITV or anything
Pipe or nipple? If its a nipple then it probably goes to question 1.
Thanks
np
Jose!</TD></TR></TABLE>
Old Jan 17, 2005 | 10:38 PM
civicdust's Avatar
Default Re: need helpw ith swap (Luserkid)
1. Yeah charcoal canister. Under the PCV theres a nipple, where does that go to ?
2. It is located on the bottom side of the throttle body and under the gas cable holder(where the end of the gas cable hooks up to [the golden thing]) [the one that opens the butterfly?]
3. its a nipple on the manifold, right next to the head and its pointing up.
Ill check to see if i find a pic
Old Jan 17, 2005 | 10:57 PM
Luserkid's Avatar
This should solve your throttle body question:
And this should help you with the charcoal canaster and the manifold questions:
Old Jan 17, 2005 | 11:43 PM
civicdust's Avatar
kinda hard to see, so here i dotted the areas where the nipples are found
Old Jan 18, 2005 | 12:24 AM
Luserkid's Avatar
Ok the dot thats on the valve cover goes into your intake, its for return oil.
Check to see if your motor has that nipple on the throttle body for the PCV if not then the nipple in the middle of the manifold is for the PCV.
If you could get me actual pictures i could help you better.
Old Jan 20, 2005 | 01:32 AM
civicdust's Avatar
Old Jan 20, 2005 | 07:41 AM
Luserkid's Avatar
I cant see where your number 2 goes to.
Your top one that you sent 2 pointers to you dont need to cover that, unless if your going to BAR your car. Ive seen people without it on.
Your number 1 thats circled in red is coolant for your FITV, you need to send a line over to the head of your motor, theres a port for it if you follow your upper rad. hose to your head, right where the bleeder valve is there should be another spot to add that line. (provided number 1 is pointing under the TB.)
Old Jan 20, 2005 | 11:35 PM
civicdust's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I cant see where your number 2 goes to.
Your number 1 thats circled in red is coolant for your FITV, you need to send a line over to the head of your motor, theres a port for it if you follow your upper rad. hose to your head, right where the bleeder valve is there should be another spot to add that line. (provided number 1 is pointing under the TB.)</TD></TR></TABLE>
OKay, number one....i searched for a port but didnt find one, WE ARE SPEAKING OF A D15B, right?...nowhere near the bleeder.
Also...#2 is on the manifold. It throws water out. So im guessing the fitv and the one in the manifold are similar cuz they carry water, and it wouldnt be normal to just put them together....So...what can i do?
Old Jan 21, 2005 | 01:34 PM
civicdust's Avatar
Okay here you can see the two i was talking about.
Where do they go?
(the ones with the hoses)
Old Jan 22, 2005 | 04:26 PM
civicdust's Avatar
okay maybe this can help.
the nipple pointing up, is the one near the head, and well the other one is with the hose, im guessing fitv?
Old Jan 22, 2005 | 06:12 PM
civicdust's Avatar
bumpie
Old Jan 22, 2005 | 08:52 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jose! &raquo;</TD></TR><TR><TD CLASS="quote">okay maybe this can help.
The one with the hose is the FITV, im not really sure what the upper nipple is though.
B18c1-Integra
13
Feb 22, 2008 05:34 PM
sparco civic97
Mar 24, 2004 11:11 AM
SlowLow5thGen
Jan 7, 2003 11:40 AM
Turbo Powa
17
Jun 18, 2002 11:31 AM
