major power loss, need some help/ advice
Old Jan 17, 2005 | 03:50 PM
boostedsol's Avatar
Default major power loss, need some help/ advice
After boosting a few nights ago, my car has a total lack of power. I did a compresion test: 160, 175, 170, 165 are the results... slight blow by in the crank case, and also the 160 cylinder #1 spark plug was wet with oil. It almost feels like ignition break up when i am driving it. I guess it could be a piston or ringland... anyone have any ideas?
Old Jan 17, 2005 | 08:38 PM
Tapen00n's Avatar
Default Re: major power loss, need some help/ advice (boostedsol)
did you retard your timing at all.....or do you have stock fuel system???
Old Jan 17, 2005 | 10:16 PM
turtle-eg's Avatar
Where is the oil on the spark plug? On the engine side or spark plug wire side? If it's on the wire side, it's the valve cover spark plug seals leaking and causing a misfire.
Old Jan 17, 2005 | 10:37 PM
DRIVENRacing's Avatar
do you have a dump tube?
Old Jan 18, 2005 | 06:27 AM
boostedsol's Avatar
Default Re: major power loss, need some help/ advice (Tapen00n)
my timing is at 13 deg right now and gets adjusted through the AEM ems. my timing should be at 16 deg though... I don't know what happened but the plug is wet from the spark side, not the wire side.
Old Jan 18, 2005 | 06:33 AM
GDM Z28's Avatar
leak down test? does it sound like a wrx? when u give it gas it breaks up? my last motor did that and i....crack rings, melted ringlands, and spun a bearing ...who said LS's cant handle 28psi on a t04e lol
Old Jan 18, 2005 | 07:27 AM
PrettyLude's Avatar
mines did that too, when the ringlands gave, i had alot of oil on the bottom side of the plugs
Old Jan 18, 2005 | 08:14 PM
boostedsol's Avatar
Default Re: (PrettyLude)
yeah it breaks up bad when i give it gas... and there is no power. Must be the rings then. damn this sucks
Old Jan 18, 2005 | 08:25 PM
sporkcrx's Avatar
Default Re: (boostedsol)
How bad does the break up feel? Anyone know how to test for broken ringlands?
Old Jan 18, 2005 | 08:29 PM
boostedsol's Avatar
Default Re: (sporkcrx)
the thing that kinda gets me is that there is no smoke pouring out the crank case breather.... on my last motor when the rings went, it was like a choo choo train of smoke out the crank case breather and oil cap.
Old Jun 13, 2005 | 08:01 PM
Turbo Dan's Avatar
turbo could be seized or something could be slowing it down?
nix94delsol
May 18, 2009 12:41 PM
lethalgsr32
Dec 31, 2005 03:50 PM
lethalgsr32
Dec 31, 2005 01:37 PM
QUICKERSILV3R
Oct 28, 2005 01:05 PM
typesguy
Nov 24, 2003 06:33 PM
