Suspension & Brakes Theory, alignment, spring rates....
swapped hatch - which springs?
Old Jan 17, 2005 | 03:42 PM
eggie75's Avatar
Default swapped hatch - which springs?
i bought tokico hp shocks and springs on my swapped hatch. the drop wasn't enuf for me so i bought a diff set of springs. i went with intrax because of ride quality. now the car does a nose dive. i assume that their advertised ride quality is because of a low spring rate, and the added weight from the swap lowers the front. i also do not like the ride... its way too soft. if i went with some eibachs or h&r's would i have the same nose dive prob? or should i get integra springs? i wanted about a 1.8" drop.
Old Jan 17, 2005 | 05:01 PM
SickWitIt2.0's Avatar
Default Re: swapped hatch - which springs? (eggie75)
What are the dorps on the new ones.?....Well one other thing alway know whats the spring rate.? depending on what you want to do with the car!............figure what they are in the front.(call up) were you bought them from!..They might know...wish I can help a little more.
Old Jan 19, 2005 | 03:54 AM
eggie75's Avatar
Default Re: swapped hatch - which springs? (SickWitIt2.0)
if i remember rite, the front were 300... they couldn't give me the rate for the rear, and i asked the rate for integra springs, and they couldn't give me that either. i'm not looking to ax, but i do want good handling. i drove a b16 hatch w/ skunk sleeves... i thought they were a little harsh. damn... with all the money i spent trying diff setups, i could've got a set of omni coilovers or something.
Old Jan 19, 2005 | 04:25 AM
.RJ's Avatar
.RJ
Ground Control
Old Jan 19, 2005 | 05:44 AM
ki3t's Avatar
This user can set his title.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 &raquo;</TD></TR><TR><TD CLASS="quote"> i wanted about a 1.8" drop.</TD></TR></TABLE>
Eibach
Old Jan 19, 2005 | 09:14 AM
eggie75's Avatar
Default Re: swapped hatch - which springs? (ki3t)
should i get civic springs or integra springs?
JPerkMr954
Suspension & Brakes
Jan 18, 2011 01:10 PM
661rex89si
Suspension & Brakes
Aug 14, 2010 08:16 PM
BlueRex1020
Feb 9, 2007 04:43 PM
92CivicLSI
17
Nov 11, 2004 02:04 PM
loki2323
Sep 10, 2002 06:20 PM
