Diameter of ITR hubs and hub opening for Slipstreams?
does anyone know the diameter of itr hubs and hub opening for slipstreams
i need to get hubcentric rings today for my r and dont have time to measure everything , and dont have the wheels with me right now . does anyone know this off hand so i cant just order them now . . . . .thanks guys.
Slipstream:
When i got centering rings for my volks (same size as the slipstreams), i got some konig centering rings, they're 73.0 OD, and 64.15 Inner Diamater. I think the R hub is 64mm.
edit: yeah, i thought i had a pic:
[Modified by Aleph, 10:45 AM 1/11/2002]
thanks dude. . . . . im glad someone else needed em too ., other people were telling me i dont need em
You shouldn't absolutely need them, but they exist for a reason...were you using tapered lugs (instead of rounded stock lugs) when you put the wheels on?
i was using tapered lug nut, they are tight when they are tightened , but wobbly as hell?
i dont knwo dude, i dont wanna wreck em . or have em fall off.
Aleph: Are the Konig rings made of metal or plastic? And also, where did you purchase them? I can't find metal hubcentric rings anywhere...
Thanks,
Andrew
Thanks,
Andrew
also , i checked with A&A and they said they hub on the r is 140mm, so if the bore on the wheel is 73, it makes no sence to mount them ????? will these fit?
Andrew
Pretty much all Hondas have a 64mm hub diameter.
My GS-R had smaller than 64mm hubs. A&A must be talking about something else, becuase 140 would be a pretty damn big hub. I got the plastic rings in the picture above from http://www.tires.com ....my volks came with 2 metal rings, that are exactly the right size...but were a little tight for my tastes, you'd have to tap them on and pry them off, which isn't something i wanna do every weekend when changing rims. If i were keeping the one set on, the metal ones would be the obvious choice. Pics of the metal rings at S&M, in the volk part of the mods section.
alright on the other post every said they diodtn use em so
i alled a&aback and anotther dude there got an r all worked out . anyway he tried the rings and cracked em anyway , so he said to just thread em in evenly and make sure the nuts are seated fine and they will be fine . . . . so ill try that , if i post up a post saying my wheels fell off, please dont laugh. . .. .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs »</TD></TR><TR><TD CLASS="quote">So has this been confirmed to be 64mm???</TD></TR></TABLE>
64.15mm
64.15mm
Jaydeep
Jun 24, 2005 12:48 PM
4gen
Nov 18, 2004 10:26 PM
SEA Hag
Mar 21, 2003 06:02 AM
dwnthehatch
24
Mar 4, 2002 08:43 PM
