Turbo built block running with no turbo?
Old Jan 17, 2005 | 01:11 PM
Takumi Fujiwara's Avatar
Default Turbo built block running with no turbo?
Are there any ill effects from running a block that's built for turbo (specifically the pistons), without a turbo for long periods of time?
As everyone knows, building a turbo is expensive. I was thinking maybe building a nice strong block with forged rods, forged turbo pistons, sleeves, and then hopefully adding a turbo in about a years time.
Downfall to this is that I would most likely have to pay for tuning 2 times... but you gotta do what you gotta do sometimes...
Old Jan 17, 2005 | 01:13 PM
sporkcrx's Avatar
Default Re: Turbo built block running with no turbo? (Takumi Fujiwara)
nah, it'll be fine.
Old Jan 17, 2005 | 01:32 PM
primeredbeast's Avatar
make sure you get a good machine shop to assemble everything for you clearances and blueprint everything
Old Jan 17, 2005 | 02:16 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara &raquo;</TD></TR><TR><TD CLASS="quote">Are there any ill effects from running a block that's built for turbo (specifically the pistons), without a turbo for long periods of time?
Downfall to this is that I would most likely have to pay for tuning 2 times... but you gotta do what you gotta do sometimes...</TD></TR></TABLE>
Why would you do this? Boost your stock motor, and get used to it. If you jump right into a car with 350+ WHP it will be too much for you to handle. My stock B16 at around 220 to the tire driven daily was tons of fun for about 8 months before I got the craving for a bit more power.
Old Jan 17, 2005 | 03:33 PM
Default Re: Turbo built block running with no turbo? (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you do this? Boost your stock motor, and get used to it. If you jump right into a car with 350+ WHP it will be too much for you to handle. My stock B16 at around 220 to the tire driven daily was tons of fun for about 8 months before I got the craving for a bit more power.</TD></TR></TABLE>
I have bad compression in one of my cylinders, I'm burning a quart every 400 miles, I have 135k on my odo...
I need a rebuild... but I can't afford everything at once... which is why I want to do this.
Old Jan 17, 2005 | 04:15 PM
blackdude's Avatar
Ask Ryosuke he always has the right anwsers
Old Jan 17, 2005 | 05:20 PM
VinceVTEC's Avatar
Default Re: Turbo built block running with no turbo? (blackdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdude &raquo;</TD></TR><TR><TD CLASS="quote">Ask Ryosuke he always has the right anwsers
LOL, he sure does.
Old Jan 17, 2005 | 05:27 PM
UberTeg's Avatar
Default Re: Turbo built block running with no turbo? (VinceVTEC)
better mount that motor in the back if you want to drift down akina's downhill
Old Jan 17, 2005 | 05:32 PM
NVturbo's Avatar
O.G. triple O.G.
My stock B16 at around 220 to the tire driven daily was tons of fun for about 8 months before I got the craving for a bit more power.</TD></TR></TABLE> You made 220hp to the wheels...N/A with a "stock B16"....SURE, if you say so. IF I'm not mistaken, it takes a lot of motor work and money to even make a H22 push out that kind of HP.
Old Jan 17, 2005 | 05:35 PM
stinker504's Avatar
I think he ment stock block B16 w/ turbo. He was trying to say turbo first then build block second to get use to the power.
Old Jan 17, 2005 | 05:39 PM
VinceVTEC's Avatar
Default Re: Turbo built block running with no turbo? (UberTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberTeg &raquo;</TD></TR><TR><TD CLASS="quote">better mount that motor in the back if you want to drift down akina's downhill</TD></TR></TABLE>
Better run that by Bunta first...
Haha, sorry... back on topic.
You car will be fine.
Old Jan 17, 2005 | 06:15 PM
I checked back, all excited to hear feedback... I need to change my name... it's definitely not helping. LOL
step bump, step bump bump.
Old Jan 17, 2005 | 07:44 PM
b16sedan's Avatar
Default Re: Turbo built block running with no turbo? (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote"> You made 220hp to the wheels...N/A with a "stock B16"....SURE, if you say so. IF I'm not mistaken, it takes a lot of motor work and money to even make a H22 push out that kind of HP. </TD></TR></TABLE>
Did you actually believe I was talking about a stock N/A B16 making 220 to the wheels, or is this just a really bad joke?
Old Jan 18, 2005 | 07:46 AM
downeyballz's Avatar
ive been running a built turbo block for 4 1/2 months, with out a turbo, and everything runs fine, i cnat think of any reason why this would be bad for you motor as long as you have a good tune. you might notice a little diffrence in power if you lower compression.
J_trizz
Apr 22, 2007 08:32 AM
deeweezy187
Apr 17, 2007 08:04 AM
