i need help check engine light is on
Old Jan 17, 2005 | 11:27 AM
db8xc1x39
Guest
Posts: n/a
Default i need help check engine light is on
my check engine light is on and i believe it read p 1957 or 47 but either way it said that it was a leak in the evap system..no vacuum in canister i checked the hoses but none seem to be loose? could it be anything else?
Old Jan 17, 2005 | 01:26 PM
JimBlake's Avatar
Default Re: i need help check engine light is on (db8xc1x39)
If it was P1456 it was the gas tank section of the EVAP system. Including the gas cap. Otherwise, I bet it was P1457 for the canister section. For a hint of what you're in for, check out this thread...
https://honda-tech.com/zerothread?id=748876
Partway down I say what stuff to check on a '98/'99 Accord. The components are gonna be located differently in your Integra, but you'll get the idea. Try to get your hands on a Helm book, MityVac, multi-meter, & a couple jumper wires.
Old Jan 19, 2005 | 03:16 PM
db8xc1x39
Guest
Posts: n/a
Default Re: i need help check engine light is on (JimBlake)
thanx for the hook keep them four doors rollin!
SLEEPIN-GSR
Jul 3, 2009 06:43 AM
PearlH22
Mar 29, 2006 11:18 AM
Hesh
Jan 7, 2005 10:12 AM
CivicT
Apr 11, 2002 04:16 AM
CW_97_ITR
Nov 19, 2001 08:50 PM
