D16z6 and d16y6 is thre a difference?
Old Jan 17, 2005 | 09:40 AM
dropd4door's Avatar
Default D16z6 and d16y6 is thre a difference?
which cmae in which car and is either one better than th other?? thanks i tried search but didnt find ne useful info
Old Jan 17, 2005 | 09:57 AM
jerbear!'s Avatar
whats a d16y6?
Old Jan 17, 2005 | 10:12 AM
edmsol's Avatar
Default Re: (jerbear!)
i think he means a D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp .
Old Jan 17, 2005 | 10:16 AM
ieatrice's Avatar
Default Re: (sjonnie)
i believe the y8 has 3 more hp and is obd1. also, the tranny has stronger shift forks
Old Jan 17, 2005 | 10:20 AM
Neutex22's Avatar
Default Re: D16z6 and d16y6 is thre a difference? (dropd4door)
Distributor bolt mounting location. And about 3 to 5 HP. D16z6 92-95 models and D16y8 96-00 models.
Old Jan 17, 2005 | 10:24 AM
99hatch's Avatar
Default Re: (ieatrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">i believe the y8 has 3 more hp and is obd1. also, the tranny has stronger shift forks</TD></TR></TABLE>
y8 is obd2
Old Jan 17, 2005 | 10:35 AM
Marauder's Avatar
Default Re: (99hatch)
Slighty difference cylinder head, camshaft...
Old Jan 17, 2005 | 11:35 AM
SOHCejcivic's Avatar
Default Re: (Marauder)
z6 is obd1, y8 is obd2. z6 has 9.2:1 cpr, y8 has 9.6:1 cpr. y8 oil pumps flow 33% less than the z6. y8s have stronger shift forks. y8s supposedly have better intake manifolds (mid rpm range) but z6s flow better at high rpm range.
but my overall opinion z6&gt;y8.
Old Jan 17, 2005 | 12:12 PM
DAguyLS's Avatar
^^i agree with SOHCejcivic
Old Jan 17, 2005 | 12:19 PM
eJone powereD's Avatar
d16z6 came in 92-95 civic si/ex's and the del sol si's to my knowledge...d16y8 came in 96-00 civic ex's
Old Jan 17, 2005 | 01:13 PM
EgRedSi's Avatar
I know I still have a VTEC Si motor for the 94. The VTEC kicks in at different times (I think). Mine kicks at 4,300.
Old Jan 17, 2005 | 01:23 PM
skip.two's Avatar
Default Re: (SOHCejcivic)
92-95 Civic/Civic Hatchback EX/Si
93-95 Del Sol Si...
D16Z6 SOHC VTEC - 125hp 106lbs/ft tq - OBD1
96-00 Civic EX...
D16Y8 SOHC VTEC - 127hp 107lbs/ft tq - OBD2a/b (96-98/99-00)
D16Z6 tranny has aluminum shift forks.
D16Y8 tranny has steel shift forks.
D16Y8 shortblock is better than the D16Z6 shortblock.
D16Z6 head flows better than the D16Y8 head.
D16Y8 intake manifold is better than the D16Z6 intake manifold.
Old May 8, 2024 | 11:43 AM
Bo sun's Avatar
d16y6 only came in the vti models for Newzealand and Pakistan I think. Its different to d16y8
iheartjayDem
Aug 18, 2006 07:36 PM
rasinhell
Dec 7, 2004 04:32 AM
Unit02VXHatch
Nov 6, 2004 11:07 PM
95EXcivicsleeper
32
Jun 24, 2004 01:15 PM
static_signal
Nov 25, 2003 04:45 AM
