stock headlights
Old Jan 17, 2005 | 09:23 AM
949's Avatar
949
Default stock headlights
does anyone know how to open the stock headlights. should i use the oven? if so what is the temp that i should use? how long should i keep it in the oven?
Old Jan 17, 2005 | 09:29 AM
-RedneckDave-'s Avatar
Working
Default Re: stock headlights (949)
I did mine like this. I heated the oven to 200 degrees and then turned it off and wrapped the housings in aluminum foil and left them in there for 5 minutes. Then I pulled them out and used a screwdriver to seperate the lens.
Old Jan 17, 2005 | 10:17 AM
ucb's Avatar
ucb
Default Re: stock headlights (-RedneckDave-)
I heated the oven to 350 for 10 minutes, turned it off, then stuck the lights in for 5 minutes
Dont forget to clean the inside of the lenses before you put them back together
I didnt and it looks all fuzzy inside
Old Jan 17, 2005 | 10:20 AM
Working
Default Re: stock headlights (UCBGSR)
lol nice
Old Jan 18, 2005 | 12:01 AM
949's Avatar
949
nice. im doing a projector hid retrofit so will i need to get a new sealer glue?
99hondav6
Sep 3, 2008 10:10 AM
kr3nse0ulja
Apr 1, 2006 09:18 PM
thomst4R
Jul 24, 2005 04:58 AM
acatak
Apr 29, 2003 05:31 AM
CivilizedCiv
15
Jun 6, 2002 05:33 PM
