Lower Control Arms
Old Jan 17, 2005 | 08:41 AM
Burgh's Avatar
Default Lower Control Arms
Anyone make LCAs for the EP? If so who? And anyone have them?
Old Jan 17, 2005 | 08:48 AM
jsek's Avatar
Default Re: Lower Control Arms (Burgh)
Specialty Products offers a set. http://www.spcperformance.com
Old Jan 17, 2005 | 10:05 AM
Halo's Avatar
king motorsports dc5r lca's for the front..don't forget the dc5r front sway also..these will also push the bottom of your wheels out 15mm
Old Jan 17, 2005 | 02:01 PM
Burgh's Avatar
Default Re: Lower Control Arms (Halo)
Thanks. That Mugen piece looks like something along the lines of what I was looking for. So it pushes the bottom of the wheel out about 15mm? Using trig, and based on a 15" wheel, that works out to about 2.25 degrees (if you're pivoting at the top of the wheel) or 4.5degrees (if you're pivoting at the center of the wheel). Anyone know what the real camber angle gain is by using these LCAs? Is this LCA adjustable in any way at all?
I don't see where spc's website has a reference to front (or rear) LCAs for the EP?
Old Jan 18, 2005 | 06:18 AM
Todd00's Avatar
I said I don't want a title!
It's not a double wishbone design up front (as you know). I don't think it will adjust camber like you think it will.
And no, it is not adjustable. Just a longer and aluminum control arm.
Old Jan 18, 2005 | 07:54 AM
Burgh's Avatar
Default Re: Lower Control Arms (Todd00)
I kinda figured that it wouldn't have the same effect as an LCA on the older inequal length A-arm setup but I'm just trying to lay out all the details that all. Would changing camber using an LCA affect toe as much as changing camber with an upper mount camber plate?
Thanks for the info all.
Old Jan 18, 2005 | 08:37 AM
Halo's Avatar
no, adjusting toe from the crash bolt has almost no effect on toe..I was at -3 on both sides with almost 0 toe
Old Jan 21, 2005 | 08:33 PM
glw's Avatar
glw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burgh &raquo;</TD></TR><TR><TD CLASS="quote">I kinda figured that it wouldn't have the same effect as an LCA on the older inequal length A-arm setup but I'm just trying to lay out all the details that all. Would changing camber using an LCA affect toe as much as changing camber with an upper mount camber plate?
Thanks for the info all. </TD></TR></TABLE>burgh,
it seems to me that if you are moving the lower knuckle mounting position out, then the lower strut mount position is also going to be moved out adding negative camber...
Honda knowledge
Apr 15, 2015 10:41 AM
whyS0serious
16
Jun 27, 2010 02:27 PM
Initial_drift
Feb 13, 2008 02:17 PM
rudeman85
Oct 28, 2004 03:34 PM
deeksmooth
Oct 25, 2004 07:48 AM
