Tach sticks
I have a problem with my stock tach sticking at 2000 RPM's at idle(900 rpm) and at 3500 while accelerating, kicking back on line once the vtec jumps in. I just did a swap to a d16z6 with a manual P28 ECU. Dose any body know what's going on.
TRY CHECKING YOUR GEAR SENSOR IN THE TRANNY AND PUT LITHIUMGREASE INSIDE THE CONNECTOR BOX. IT MAY BE A POSSIBILITY
THE CONNECTORS ARE DIRTY. USE CONTACT CLEANER ON TERMINALS THEN APPLY THE LITIUM GREASE.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAMTUNNELVISION »</TD></TR><TR><TD CLASS="quote">TRY CHECKING YOUR GEAR SENSOR IN THE TRANNY AND PUT LITHIUMGREASE INSIDE THE CONNECTOR BOX. IT MAY BE A POSSIBILITY
THE CONNECTORS ARE DIRTY. USE CONTACT CLEANER ON TERMINALS THEN APPLY THE LITIUM GREASE. </TD></TR></TABLE>
<FONT SIZE="40"> TURN OFF YOUR CAPS LOCK</FONT>
stealth89hatch
13
Jun 17, 2005 03:25 PM
