wtf... why is my valve cover "sweating"
Old Jan 17, 2005 | 03:40 AM
alfaaay's Avatar
Default wtf... why is my valve cover "sweating"
I threw this on yesterday because I had to make some cam gear adjustments and adjust timing. On spots around the valve cover (especially the letters), it looks like it's getting oily/wet/sweaty whatever. I don't understand why this is happening. I tried wiping it up with a rag to see if anything rubbed off, but nothing did unless I applied hella pressure. The paint I used was rattle-can camo paint used for painting cars. Perhaps it has to do with the paint standing up to the heat? ....
Don't mind the blue vacuum hose, I'll get a better one when I get the chance.
I'm going to re-paint it some other color since it's doing this. What type of paint are you guys using to paint your VC's?
Old Jan 17, 2005 | 04:48 AM
NrG's Avatar
NrG
too much vtec?
Old Jan 17, 2005 | 04:49 AM
JoshuaVTEC's Avatar
Default Re: (NrG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG &raquo;</TD></TR><TR><TD CLASS="quote">too much vtec?</TD></TR></TABLE>
/thread
Old Jan 17, 2005 | 05:13 AM
Rod.'s Avatar
Default Re: (NrG)
maybe not enough
Old Jan 17, 2005 | 05:23 AM
K.F14's Avatar
Default Re: wtf... why is my valve cover "sweating" (alfaaay)
Old Jan 17, 2005 | 05:27 AM
BoostedJeff's Avatar
Default Re: (JoshuaVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
/thread</TD></TR></TABLE>
Old Jan 17, 2005 | 06:07 AM
prayludin's Avatar
Default Re: (BoostedJeff)
least you know its workin hard for ya
Old Jan 17, 2005 | 03:20 PM
alfaaay's Avatar
Default Re: (prayludin)
Old Jan 17, 2005 | 03:21 PM
Mizz CrV2003's Avatar
Default Re: (NrG)
Old Jan 17, 2005 | 03:25 PM
rodrez.'s Avatar
Shouldn't be the paint, you can use regular spray paint on a valve cover, and it will last. That's weird. Did you get a closer look or smell it to see what it was?
Old Jan 17, 2005 | 03:29 PM
CRX_1.8T's Avatar
How long ago did you spray that on there? Is there a possibility that the paint may be a little moist for some reason?
Old Jan 17, 2005 | 03:30 PM
papa5murf's Avatar
Default Re: wtf... why is my valve cover "sweating" (CRX_1.8T)
uhhh. thats strange...
Old Jan 17, 2005 | 03:32 PM
JL's Avatar
JL
probably too cold, or moisture in the air? where did you paint it.. i know its been very cold in washington, and raining for a few days now
Old Jan 17, 2005 | 03:54 PM
jbell's Avatar
Default Re: wtf... why is my valve cover "sweating" (JL)
its sweating from all the horsepower.
Old Jan 17, 2005 | 04:00 PM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: wtf... why is my valve cover "sweating" (jbell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">its sweating from all the horsepower. </TD></TR></TABLE>
Old Jan 17, 2005 | 04:01 PM
BS 22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG &raquo;</TD></TR><TR><TD CLASS="quote">too much vtec?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC &raquo;</TD></TR><TR><TD CLASS="quote">/thread</TD></TR></TABLE>
Old Jan 17, 2005 | 04:03 PM
mrdanglez's Avatar
Old Jan 17, 2005 | 04:20 PM
mookie's Avatar
its hot
Old Jan 17, 2005 | 04:31 PM
1993sir05's Avatar
condensation anyone?
Old Jan 17, 2005 | 04:34 PM
CWESTINAP1's Avatar
i have a little bit of that too.
Old Jan 17, 2005 | 04:36 PM
gaydm.accord's Avatar
liek sweaty palms it might need to go under the knife.
Old Jan 17, 2005 | 04:40 PM
JDMKiddo's Avatar
Default Re: (NrG)
follows the too much vtec bandwagon
Old Jan 17, 2005 | 04:43 PM
mEr's Avatar
mEr
Default Re: (NrG)
haha thats funny.....anyway, just looks like oil spots, is it a flat paint? if it is, then there most likely just oil spots....
Old Jan 17, 2005 | 05:11 PM
wutthebun's Avatar
might be oil spots from before u painted the cover.. did u clean everything up properly before u started applying the new paint? if not it might be the old residue creeping up the paint when ur motor gets hot.....
Old Jan 17, 2005 | 05:19 PM
Jules Winnfield's Avatar
Default Re: (wutthebun)
breath...stretch...shake...let it out!!
