check engine light
i am putting the b16a in my 89 crx, and i have heard from some people that the light will be on all the time whe i do the swap. Is it true, i don't think it is , but is it.
Modified by folta2169 at 11:24 PM 1/17/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by folta2169 »</TD></TR><TR><TD CLASS="quote">i am putting the b167a in my 89 crx, </TD></TR></TABLE>
change that number and get back to us.
edit: if you meant b16a, then no the light wont be on if you do everything right.
if you mean b17a, then I have no idea.
A b17 is a destroked ls with a vtec head if I'm not mistaken, someone correct me if I am. Anyhoo, if you wire the second o2, vetc, and oil pressure switch up correctly you will have no issues with either swap. Search around and figure out all the parts you need before you do the swap. The search function here is your best friend. Good luck.
The engine light will be on if the engine is not installed or running correctly. Or if the engine is damaged for some reason. For example, if the MAP sensor is malfunctioning, ithe ECU will throw 3 blinks (at least in a B18A).
cliffjumpercrx
Jan 14, 2003 09:01 PM
