question about replacing icm ( ignitor ) with msd box
Old Jan 16, 2005 | 10:02 PM
bleedblue94's Avatar
Default question about replacing icm ( ignitor ) with msd box
i have a b series motor and ive had this msd 6al box on it for a couple years now. in that time ive gone through 2 ignitors and now ive just toasted a third. i did some searching and found that the 6al box is the cause of the problem. ive also heard of people replacing the ignitor with the msd box, but almost all the people ive read about doing this have standalone systems and not stock ecus.
http://filebox.vt.edu/users/po...l.jpg
i found this in a post which describes how to bypass the ignitor completely and let the 6al box be its substitute, but i also read somewhere that this may cause your ecu to fry (im not quite sure why though). i just wanted to ask if anyone knew anything about this before i hook it up the way it is in the diagram. please lmk if you are familiar with this thanks
Old Jan 16, 2005 | 10:21 PM
PrettyLude's Avatar
i wanna know this also
Old Jan 16, 2005 | 10:26 PM
Default Re: (PrettyLude)
bump
Old Jan 17, 2005 | 07:18 AM
tgreaves's Avatar
Default Re: (bleedblue94)
I know you can do this with the AEM EMS but I didnt know you could with the stock ecu.. On the AEM box we just hook the white wire from the msd to the coil output of the AEM box..
Old Jan 17, 2005 | 08:04 AM
Default Re: (tgreaves)
well i know you can do it with the ems....thats why im asking if its k to do with the stock ecu.....anyone know for sure?
im gonna call msd today to ask them as well
Old Jan 17, 2005 | 04:56 PM
Default Re: question about replacing icm ( ignitor ) with msd box (bleedblue94)
ttt
Old Jan 17, 2005 | 06:56 PM
Brian_92GSR's Avatar
New User
It can't be done like that. There may be some other way of doing it, but connecting the MSD directly to the ECU can't be done with the stock ECU.
Old Jan 17, 2005 | 07:47 PM
Default Re: (Brian_92GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian_92GSR &raquo;</TD></TR><TR><TD CLASS="quote">It can't be done like that. There may be some other way of doing it, but connecting the MSD directly to the ECU can't be done with the stock ECU.</TD></TR></TABLE>
does anyone know if there is a way to do it
and can you explain to me why it cant be done that way please?...im not being an *** im just trying to learn why not
Old Mar 29, 2005 | 05:36 PM
TRuST's Avatar
Just giving this a bump to see if anyone has tried this mod with a stock ECU. Since, my ignitor just when cause of MSD ignition.
Nevermind..I found the solution in a archived posting.
https://honda-tech.com/zero...age=1
Modified by TRuST at 10:01 PM 3/29/2005
GRAVEDIGGER
Oct 19, 2003 01:48 AM
hobo79
Jul 12, 2003 04:34 PM
