Help w/ Hondata H22A need base map and suggestions for tunning
Old Jan 16, 2005 | 09:10 PM
allwhitehonda's Avatar
Default Help w/ Hondata H22A need base map and suggestions for tunning
I have an H22A in my integra I just purchased a used Hondata Stage 4 I am looking for a base map even if it is from s200 i can use it because i can convert it. If anyone has a basemap they could send me it would be great.
thanks alot
william
also if anyone is looking for a Skunk2 h22a Intake manifold I am selling it because it dosnt fit in an integra
Old Jan 17, 2005 | 12:12 AM
k_spek's Avatar
Default Re: Help w/ Hondata H22A need base map and suggestions for tunning (allwhitehonda)
You can probably also use a gsr map to start out with.
Sorry I lost my old base map chip otherwise I would send it to you.
Old Jan 17, 2005 | 01:21 AM
Default Re: Help w/ Hondata H22A need base map and suggestions for tunning (DynamicEG22)
ok i will start with a gsr but if anybody has a basemap for H22A please let me know I really would rather use that one. Especially a stock JDM or USDM H22A basemap.
Is there a way to read the rom that is on a stock ecu??? I dont have a stock ecu but maybee i could find one? i have the rom programer and reader
Old Jan 17, 2005 | 06:08 PM
PirateMcFred's Avatar
Hondata should provide you with a basemap. Call them up.
Old Jan 17, 2005 | 07:46 PM
k_spek's Avatar
Default Re: Help w/ Hondata H22A need base map and suggestions for tunning (PirateMcFred)
I don't think hondata has a base map for a H22a. The problem is that the p13 map is difficult to copy and run on a p28 chip and ecu.
Honestly your best bet is to start with a gsr map and turn your fuel pressure up.
Old Jan 17, 2005 | 07:55 PM
H22ek4's Avatar
Your tuner should have a base map from hondata.
Old Jan 18, 2005 | 12:29 AM
Default Re: Help w/ Hondata H22A need base map and suggestions for tunning (H22ek4)
first off my tuner wont have a basemap since hondata dosnt have a basemap.... i need a basemap from someone else.... it sounds like my best bet for now is a gsr map but my real best bet is finding someone with a tuned light N/A prelude map
and thats what im looking for either a tuned or stock H22a map
thanks
will
and no my tuner wont have anyting hondata didnt give them which includes the lack of a stock h22a map
Old Jan 18, 2005 | 12:37 AM
flip1199's Avatar
well when u ordered the hondata the shop shoulda asked u what your setup would be so that they can put a base map on there. when i ordered mine last year, they set it up perfectly for me to run 550's on a LS ecu.
Old Jan 18, 2005 | 04:50 AM
flyrod's Avatar
Default Re: Help w/ Hondata H22A need base map and suggestions for tunning (flip1199)
They tell people that they have a H22 basemap. Call them and ask for it.
Old Jan 27, 2005 | 11:15 AM
jdmGSR.fo0!'s Avatar
Default Re: Help w/ Hondata H22A need base map and suggestions for tunning (flyrod)
how much for skunk intake mani?
Old Jan 27, 2005 | 01:02 PM
mgags7's Avatar
hondata publishes a basemap for the h22 type s......
that should work for you fairly well for the time being....
Old Jan 27, 2005 | 02:24 PM
Boost3d22's Avatar
hondata dosent have a h22a base map, B.c if you have a p28 , its made for the gsr and civics, and controls less functions then the h22a requires, such as the secondary butterflys
Old Jan 27, 2005 | 02:55 PM
mgags7's Avatar
^^stop talking out of your *** and listen to the guy holding a rom with an h22 basemap on it, straight from my s200 tuner.....
just because it doesnt control knock and IAB doesnt mean that it cant provide igniton and fuel tables
RiceFed
Mar 12, 2008 01:51 PM
ripsta
Aug 7, 2007 07:09 AM
ripsta
Aug 4, 2007 07:47 PM
ripsta
Aug 4, 2007 11:46 AM
fastrcars
Jan 20, 2006 04:18 AM
