How do you know you've blow yer motor ?
Old Jan 10, 2002 | 09:53 PM
X2BOARD's Avatar
Default How do you know you've blow yer motor ?
I have some probs here and there, but as far as a turbo motor (or otherwise) what are the typical signs of the motor being blown ?
Old Jan 10, 2002 | 09:59 PM
bigTom's Avatar
Default Re: How do you know you've blow yer motor ? (X2BOARD)
usually when it doesnt work or wanna start anymore... or when it smokes ALOT...
Old Jan 10, 2002 | 10:00 PM
MiraiZ's Avatar
low or no compression, a lot of smoking, irratic idle speeds, poor performance, raddling noises, and/or car does not start at all
Old Jan 11, 2002 | 04:44 AM
Mista Bone's Avatar
D Tranny Guru
Old Jan 11, 2002 | 05:25 AM
RGAZ's Avatar
New User
Default Re: How do you know you've blow yer motor ? (Mista Bone)
Bone,
You must post that picture of the block 10 times a day. It is hilarious but you gotta get a new one.
As for the original question:
A rpm based knocking sound, excessive oil burning, low/no compression on a cylinder. Any abnormal clunks are all signs of the motor being shot.
Randy
Old Jan 11, 2002 | 07:24 AM
VTC_CiViC's Avatar
Default Re: How do you know you've blow yer motor ? (RGAZ)
Metalic fragments in the oil are a sign of rings headed out the door..
Old Jan 11, 2002 | 09:54 AM
threatcon13's Avatar
New User
Default Re: How do you know you've blow yer motor ? (VTC_CiViC)
something that i noticed yes..and all the other signs are good..i had crazy smoke out of the exhuast, and a wannabe purge valve like smoke coming from under my hood. also, the low compression
Old Jan 11, 2002 | 01:55 PM
boosted3g's Avatar
Default Re: How do you know you've blow yer motor ? (turbo01gsr)
Dont worry Mistabone Hondabond will fix that right up.
Old Jan 11, 2002 | 02:09 PM
Kamin's Avatar
Default Re: How do you know you've blow yer motor ? (boosted3g)
haha
Old Jan 11, 2002 | 06:50 PM
miller's Avatar
Default Re: How do you know you've blow yer motor ? (KAMiN)
hondabond can fix anything!!
Old Jan 12, 2002 | 12:50 AM
NOSed_b18b's Avatar
Default Re: How do you know you've blow yer motor ? (vtecdoc)
Shiet.....JB weld will fix anything you mean. That stuff is ******* amazing!!
Old Jan 12, 2002 | 05:09 PM
1's Avatar
Default Re: How do you know you've blow yer motor ? (NOSed_b18b)
Old Jan 13, 2002 | 12:09 PM
X2BOARD's Avatar
Default Re: How do you know you've blow yer motor ? (1)
looks like you got slimed...
Old Jan 14, 2002 | 09:22 AM
turbopanda's Avatar
how do you know? well, you know for sure once you take the pistons out of your engine, and some/all of them look like this..
Old Jan 14, 2002 | 10:31 AM
InfamousRS's Avatar
How does this happen, it looks like the rod hit the side of the block. Doed the block flex so much that it just makes contact?
Old Jan 14, 2002 | 11:08 AM
SJP0tato's Avatar
Default Re: How do you know you've blow yer motor ? (BLK94RS)
Looks like a thrown rod bolt to me.
Ryan P.
wildstylz's Avatar
I blew a motor before.....I had a serious Rod knock...You should know off the bat....mostly becuase the idle isnt right.
Old Jan 14, 2002 | 06:04 PM
turboex's Avatar
Default Re: How do you know you've blow yer motor ? (wildstylz)
hey is that a pic of mine nathan's boosted civic??? LOL
how did yours happen???
mine was the wastegate sticking damn delta!
blake22
Nov 12, 2008 06:03 PM
adam1027
Jun 29, 2007 09:26 PM
revvin9k
Jun 28, 2005 12:58 PM
AzN_Flava
Apr 18, 2005 12:02 PM
BOOSTIN1
Apr 26, 2004 06:52 PM
