ls head on b20 block efficient?
Old Jan 16, 2005 | 05:34 PM
bryanb2's Avatar
Default ls head on b20 block efficient?
hey i was thinking about building a b20 but i love the torqueness of the ls so is it practical to build a b20 bottom end with a ls head or is that a no no? i like my ls and am not worried about vtec right now, i wanna do somethin different then most of the others around here. just wondering if its worth doing or should i just get a blank ls bottom end and build that.. thanks for your help
Old Jan 16, 2005 | 05:59 PM
v4lu3s's Avatar
RTFM
its the same head. though the ls has better cams.
and the b20 has more stock torque than teh ls anyway.
Old Jan 16, 2005 | 09:48 PM
orng1's Avatar
Default Re: (v4lu3s)
The B20 and ls are different heads. The ls has a smaller combustion chamber so when you install it on a b20 yopu will have higher compression.
Old Jan 17, 2005 | 06:41 AM
horizongreyEJ1's Avatar
Default Re: ls head on b20 block efficient? (bryanb2)
The b20 has more tq than the LS, and if I were you I would put a B16 head on there insted of the LS or B20 head. I know you didn't say anything about Vtec but just food for thought
Old Jan 17, 2005 | 01:28 PM
bryanb2's Avatar
Default Re: ls head on b20 block efficient? (blk92civichb)
thanks for the advice,.. so putting a ls head on the b20 wouldnt be good for turbo because it would raise the compression? even if i built the bottom end with turbo pistons? thats basically what im after is a good starting point for a turbo motor. with no v-tec. kinda want somethin different then every other person around here... seems like everyone and there brother has a b-16, not saying its a bad motor at all, i just wanna do somethin a lil different.like what would be the best bottom end and ive been told b20s were strong but wasnt sure. or should i just stick with my ls and build that? what do you guys think would be a better route ... thanks alot for your help
Old Jan 18, 2005 | 05:21 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryanb2 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the advice,.. so putting a ls head on the b20 wouldnt be good for turbo because it would raise the compression? even if i built the bottom end with turbo pistons? thats basically what im after is a good starting point for a turbo motor. with no v-tec. kinda want somethin different then every other person around here... seems like everyone and there brother has a b-16, not saying its a bad motor at all, i just wanna do somethin a lil different.like what would be the best bottom end and ive been told b20s were strong but wasnt sure. or should i just stick with my ls and build that? what do you guys think would be a better route ... thanks alot for your help </TD></TR></TABLE>
The important thing to remember here is that the B20 and the B18B are practically one and the same motor! The only REAL difference is the bore diameter: 81mm for the LS and 84mm for the B20. So think of the B20 as an LS motor that is just better. Also, you could take a B18B and resleeve it to 84mm. And you would basically have the same thing as a B20. This would cost more than buying a whole B20. But it would give you a stronger motor. And you would have the B18B block stamp (important where you have to deal with a visual smog inspection). Just keep in mind that if your LS is a B18A (1990-1993), then your head is actually inferior. The B20 head is actually the B18B head, which is better than the B18A head. And I would not recommend using the older head on a larger motor. On the other hand, the B18A block is identical to the B18B block.
Old Jan 18, 2005 | 07:39 PM
crazykid9137's Avatar
i wouldnt recommend it, since the b20 is just as torqy as the ls plus some. Its got a much higher displacement and its a wase of time to put an ls head on it. I would just grab a b16 head and shave it and tap it and then throw it on the b20 bottom end and build a b20/vtec. You would run much better.
low&slowef
Mar 5, 2011 03:02 PM
jdm91CrxSi
Sep 26, 2007 07:55 PM
SCIVIC94
Mar 3, 2005 06:57 PM
B20BHatch
Aug 12, 2004 08:40 PM
