JUst did b18 Rebuild!! Massive smoke help
Old Jan 16, 2005 | 05:31 PM
kikwear002's Avatar
Default JUst did b18 Rebuild!! Massive smoke help
Ok ill give you a brief of what i did so far.
Rebuilt entire b18b1 motor, used old piston/rods , crank, valve train.
All new gaskets and seals all the way around.
The only thing is that the valve stems are supposed to be marked different and the ones i got from felpro where the same. After installing everything the motor is smoking like a train. White smoke, i know it is oil because the whole exhaust is coated with oil inside. Im thinking valve stem seals are bad. Has anyone ever had this problem? what seals did you use? Oh also i have a gsr oil pump on my ls motor, but that should not be the problem. Let me know. THANK!
Old Jan 16, 2005 | 05:41 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: JUst did b18 Rebuild!! Massive smoke help (kikwear002)
Okay, really stupid question......how long did you run the motor? Did the smoke continue to come out even after about 10 minutes of running?
Old Jan 16, 2005 | 06:36 PM
AngelTeg's Avatar
Default Re: JUst did b18 Rebuild!! Massive smoke help (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Okay, really stupid question......how long did you run the motor? Did the smoke continue to come out even after about 10 minutes of running? </TD></TR></TABLE>
good question... not stupid.... You gotta give the rings time to seat/seal...
you did buy new rings, right?
-Mike
Old Jan 16, 2005 | 06:55 PM
ernald711's Avatar
Default Re: JUst did b18 Rebuild!! Massive smoke help (AngelTeg)
doing the same rebuild... hope this doesn't happen to me... any other problems you encountered??
Old Jan 16, 2005 | 06:56 PM
kikwear002's Avatar
Ran motor ideling for about 30 mins, even took it for a short ride. Im really leaning to valve stem seals. I searched and found some other things like this, ( cloud of smoke comming from your tail pipe ) which is what mine is doing.
Yes piston rings are brand new.
Old Jan 16, 2005 | 07:20 PM
Bspec18's Avatar
Default Re: (kikwear002)
take out the spark plugs and see if their wet, I would agree with you it could be the valve stem seals
Old Jan 16, 2005 | 07:22 PM
stareatsun's Avatar
White smoke is not oil. Its coolant. Maybe u screwed up the headgasket install.
Old Jan 16, 2005 | 07:36 PM
kikwear002's Avatar
headgasket is perfect, it is oil because i stuck my finger in the muffler and it came out drecnehd with oil. SPark plugs had oil on them too.
Old Jan 16, 2005 | 07:59 PM
wilntegra's Avatar
well im going through ur same problem so what im doing in a week is getting a used gsr gen2 and dropping it in my teg.cause my car is worse ,because i rebuilt it 4 months ago and the first month it ran good but the power keepd getting lower and lower now my car still run but the smoke id too much got tired of fixing the engine so thats why im getting a better one.....wish me luck
Old Jan 17, 2005 | 04:09 AM
IMPATIENT's Avatar
Default Re: (wilntegra)
did you double check your ring placement and ring gap before installing the pistons? if you had any of your rings placed incorrectly it would cause smoke, but not a ton of oil in your exhaust., i think your prolly right about the valve seals............
Old Jan 17, 2005 | 05:28 AM
Ketone's Avatar
Default Re: (IMPATIENT)
look at the oil cap, is it milky? that could be from a headgasket leak. that would cause a lot of smoke to come out of the exhaust
Old Jan 17, 2005 | 05:33 AM
dc2integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AngelTeg &raquo;</TD></TR><TR><TD CLASS="quote">
-Mike</TD></TR></TABLE>
yeah, hopefully he didnt just throw the pistons in with the old rings... that would be moronic
Old Jan 17, 2005 | 05:35 AM
dc2integra's Avatar
Default Re: (stareatsun)
ill hold my tongue
Old Jan 17, 2005 | 07:18 AM
kikwear002's Avatar
Im not stupid enough to throw the old rings in.
Thanks for the help although. Too bad i didnt have an extra head to throw on and try that.
Old Jan 17, 2005 | 09:05 AM
ProjectDarkBlack's Avatar
did you have your cyclinder walls rebored? what kind of rings are you using? If you have anything but cast iron rings and you didn`t have the cyclinder walls resurfaced this could be a problem
Old Jan 17, 2005 | 06:22 PM
DA6righthand's Avatar
Default Re: (ProjectDarkBlack)
whoa, my friend and i just rebuilt his g2 because it bent every dman valve. we also used all new seals (felpro) and new rings along with new rod bearings. his is burning oil like a champ. and we kno its not coolant, because the oil inside the motor would be milky like someone already said. the rings that we bought were sealed power, the trick with these is that you have to pay attention to which way is up and which way is down. and we did use a ridge reamer and honer oh the cylinder walls before we put the bottom end back together. we now have the motor back apart again, and when we took out the pistons, the 2nd ring on the 3rd piston snapped, so we had to go with oem honda rings, which are really expensive. they seem like they are much higher quality than the sealed power rings. and we double checked which way rings are, which some werent on rite. and the new bearings we got were sealed power, and they were ****. in the package they were scratched, warped, totally fucked. we are waitin on new bearings, we'll see if it doesnt get better oil mileage this time....lol
thanx
justin
Old Jan 17, 2005 | 06:46 PM
kikwear002's Avatar
i sent the block in to the shop, it was honed and std bore and used with std rings. I may have used sealed power but have never had a problem in the past.
I called felpro today and they said their valve stem seals are the same for intake and exhaust... im hoping i just didnt put one on right.
Modified by kikwear002 at 8:11 PM 1/17/2005
Old Jan 17, 2005 | 09:13 PM
00s2KkId's Avatar
Default Re: (nohondayet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nohondayet &raquo;</TD></TR><TR><TD CLASS="quote">whoa, my friend and i just rebuilt his g2 because it bent every dman valve. we also used all new seals (felpro) and new rings along with new rod bearings. his is burning oil like a champ. and we kno its not coolant, because the oil inside the motor would be milky like someone already said. the rings that we bought were sealed power, the trick with these is that you have to pay attention to which way is up and which way is down. and we did use a ridge reamer and honer oh the cylinder walls before we put the bottom end back together. we now have the motor back apart again, and when we took out the pistons, the 2nd ring on the 3rd piston snapped, so we had to go with oem honda rings, which are really expensive. they seem like they are much higher quality than the sealed power rings. and we double checked which way rings are, which some werent on rite. and the new bearings we got were sealed power, and they were ****. in the package they were scratched, warped, totally fucked. we are waitin on new bearings, we'll see if it doesnt get better oil mileage this time....lol
thanx
justin</TD></TR></TABLE>
and you still installed those bearings and ran the car...
Old Jan 17, 2005 | 09:20 PM
kikwear002's Avatar
Default Re: (96GSRkId)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96GSRkId &raquo;</TD></TR><TR><TD CLASS="quote">
and you still installed those bearings and ran the car... </TD></TR></TABLE>
i thought u actually had some input about my car smoking.
Old Jan 18, 2005 | 08:05 AM
00s2KkId's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kikwear002 &raquo;</TD></TR><TR><TD CLASS="quote">
i thought u actually had some input about my car smoking. </TD></TR></TABLE>
sorry bout the thread jack man..... i hope u get ur problem resolved.....
are u going to try OEM valve seals or whats ur next step
Old Jan 18, 2005 | 08:23 AM
virusiidx's Avatar
i just rebuilt my motor and having problems with cylinder 1 not firing, i guess a lot of us have problems with rebuilds.
anyways, is there smoke coming out anywhere else besides the tailpipe, how about the valve cover or dipstick hole?
if not smoke is coming from those 2 then your problem has to be in the head. Maybe bad seals or maybe improper cam timing?
hope that helps maybe, rebuilds are a pita
Old Jan 18, 2005 | 08:41 AM
...no. definintely not. i think he might get oem bearings
Old Jan 18, 2005 | 08:44 AM
virusiidx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nohondayet &raquo;</TD></TR><TR><TD CLASS="quote">...no. definintely not. i think he might get oem bearings</TD></TR></TABLE>
acl's aren't that bad either, and they're cheap.
Old Jan 18, 2005 | 01:04 PM
00s2KkId's Avatar
yea ive heard of people puttin in acl's and they were right within spec... but oem is always good
Old Jan 18, 2005 | 01:10 PM
jdmotorsports's Avatar
i use the acl bearings and never have a problem.
sounds like either vavle steam seal or ring probleb. have you tried the "stop smoke" stuff they sell? its in a can. that has worked a few times for minor clearance problems.
