Please help~! Injectors?
Old Jan 16, 2005 | 04:40 PM
C8V6C's Avatar
Default Please help~! Injectors?
90 Civic Lx.......Dual point FI....Stock
Pulling code 16......injectors
Checked resistance on injectors....gives the right amount of ohms based on my haynes/chiltons....checked voltage to injectors with it on "on position", dunno if that did anything......but it read 8-9v
It has fuel im pretty sure...I took out the injectors and fuel was chillin in there...
Has spark, so I dont thinkk anything else is wrong
I just replaced the alt........but the only wierd thing is that I had no problems with the injectors whatsoever before.....but then it goes bad after it sits there for 3hours at work
Ive takin out the clips, and just put the connectors directly on the injectotrs.....seemed like it was a somewhat loose fit......
And Ive tried to check all other connectons....all seemd fine
Any ideas?
Thanks in advance
Modified by C8V6C at 12:09 AM 1/19/2005
Old Jan 16, 2005 | 05:44 PM
C8V6C's Avatar
Default Re: Please help~! Injectors? (C8V6C)
Anyone?
Old Jan 16, 2005 | 06:02 PM
v4lu3s's Avatar
RTFM
you tried new injectors yet?
Old Jan 17, 2005 | 06:02 AM
Perfectionist's Avatar
Need more info...
Steady CEL, or stored code?
Engine run OK otherwise?
Code 16 is a break in the electrical circuit path for the injectors. This path includes ignition switch and main relay.
Old Jan 17, 2005 | 04:41 PM
C8V6C's Avatar
Default Re: Please help~! Injectors? (Perfectionist)
I didnt wanna waste money on injectors if it wasnt the injectors.....
I tried the resistance of the injectors and it was fine, so i figured it was the wiring elsewhere....
Ive reset the ecu often......no codes and then I try to crank it......then 16 comes up everytime.....and it doesnt turn over......but it did before
So I see a short in the wire as a high chance......I guess I can just try to follow the wiring everywhere......
Old Jan 18, 2005 | 04:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C8V6C &raquo;</TD></TR><TR><TD CLASS="quote">So I see a short in the wire as a high chance......I guess I can just try to follow the wiring everywhere......</TD></TR></TABLE>
Actually, it would be an open circuit, not a short. The ECU completes the circuit to ground for each injector to pulse it.
Old Jan 18, 2005 | 11:56 AM
C8V6C's Avatar
Ill try to look at it more in depth today, thanks
Old Jan 18, 2005 | 03:08 PM
C8V6C's Avatar
Do you think that it could pull a code for injectors if its not getting fuel supply?
Im not sure how quiet an oem pump is....I know my aftermarket one in my other car is hella loud...
But Im not getting fuel at all anymore......maybe my pump/filter/wiring to pump? could be bad now
Old Jan 19, 2005 | 06:18 AM
The ECU, during code 16, has no clue and doesn't care about fuel or lack of to the injectors.
Check your main relay. You can remove the cover and resolder the joints first if you don't want to buy a new one. This usually corrects the main relay problems.
Old Jan 19, 2005 | 08:26 PM
C8V6C's Avatar
Ill check into that, thanks.....
If it is the main relay, that would explain why the fuel pump stopped working?
Old Jan 20, 2005 | 05:02 AM
Correct. One half of the relay powers the fuel pump, the other half powers the injectors.
Old Jan 20, 2005 | 07:16 AM
C8V6C's Avatar
Wonderful...ill bother you guys again if I still need help, lol
afnan
Jan 15, 2014 11:00 AM
thewrai6th
Aug 31, 2011 12:02 PM
vantta
Mar 19, 2009 05:57 PM
hoskos
Aug 27, 2007 11:22 AM
BoostedsiR
Jan 28, 2004 06:48 AM
